Mr 5 style intake
11-18-2011, 01:28 PM | #1 |
Rep 106
Mr 5 style intake
Is it possible to do this style intake without modifying the power steering bracket? I do not like to make permanent mods so if it is not possible then is there a pre-fab bracket I can buy to move it out of the way?
11-18-2011, 01:39 PM | #2 |
36
Rep 708
To get the most direct path you have to modify the bracket. On the underside of the L-shaped bracket there is a perpendicular web of material spot welded on for rigidity. I drilled out the welds and removed this large web. The resulting L-shape creates the perfect path for the hose. It is direct with minimal bends until you enter the wheel well area. The functionality of the bracket with the power steering equipment remains unchanged.
This is a permanent mod though, so pretty much the opposite of what you are asking... |
11-18-2011, 03:07 PM | #3 |
156
Rep 3,730
To fit a 3" tube in there you will need to move the resivoir 1 bolt over and modify the bracket. You can purchase a bracket from Tischer for like $15. See my DIY.
http://www.e90post.com/forums/showthread.php?t=549965
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
11-18-2011, 04:15 PM | #4 | |
Rep 106
11-18-2011, 04:18 PM | #5 |
156
Rep 3,730
Same goes for the airbox, but they are fairly expensive new. FYI I have a used one sitting around if you are interested.
11-18-2011, 04:36 PM | #6 | |
Mad Linux Guru On The Loose
1130
Rep 5,400
Drives: 2008 335i Sedan, 2023 M3
11-18-2011, 04:47 PM | #7 |
Rep 169
I'll be building one soon as well.
The only issue is getting that nice hose from McMaster Carr. They won't ship to Canada. It's so annoying to find a decent hose around here it's ridiculous. I'll paypal someone cash if they can ship about 4 feet to Canada. |
