TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > anyone w/ a PROcede/exede on the 335xi?
      05-13-2007, 09:42 AM   #1
fedinand
fedinand's Avatar
75
Drives: '11 X3, '11 GTI
anyone?
I remember reading that a couple of folks were thinking of getting one, but haven't seen/read anything since.
      05-13-2007, 11:05 AM   #2
Mrbig
106
Drives: 15 M3
335xi
I was curious about this myself. Xi would be much better for grip right !!!
      05-13-2007, 01:53 PM   #3
SGP335i
SGP335i's Avatar
Drives: 2007 335i E92 Jet Blk
I'm sure it would be pretty good, drop it a 5000rpm and hold on...
      05-15-2007, 07:57 AM   #4
fedinand
fedinand's Avatar
75
anyone?
      05-15-2007, 08:27 AM   #5
bmw0perat0r
bmw0perat0r's Avatar
53
Drives: 2015 M4 Austin Yellow
I wish. We'll see if I trust Procede in a year or two.
      05-15-2007, 08:48 AM   #6
Bravo1
Drives: Accord
Yeah as long as you don't kill your clutch or drop a diff. You will definitely get a good launch, but you may end up having to replace your clutch after a couple dozen launches. Should be very nice for your 1st to 2nd shift though as you won't have to worry about modulating the throttle as much.
      05-15-2007, 09:07 AM   #7
cadbimmer
BeeeeYaaaaa
Drives: 335xi
getting a good launch with an awd is a little trickier but as long as you slip the clutch and dont rev too high you're fine. might be a little tougher when you make 300lb/ft at 1400rpm though
      05-15-2007, 10:13 AM   #8
Bravo1
Drives: Accord
In a 335 as long as your let the clutch bite before you floor it, then you should be fine. As you build boost so early and have so much torque, I would think that an intial slip at about 3500 would be good... then once you feel the bite then mash the foot to the floor and get ready to shift
Just a clutch drop is not recommended if you want your want to keep your car in good shape. Some people with turbo cars that produce all their boost past 3000 rpm like to drop the clutch from 6000 rpm just so they can stay in boost after the car starts rolling. But if you do a launch right, you can still stay in boost even in a car that produces boost later in the rpm range.
      05-15-2007, 10:38 AM   #9
CASHBY
168
Drives: E90 335 "done up"
AWD turbo cars are a lot harder than you think to launch.
On a turbo car you really have to blip the throttle rather than just hold it at 5000 rpms and dump the clutch....because if you hold it the turbo will stop spooling because its not under load.
the trick is blip it back and forth...for example blip it from 3500rpms to 5500 rpms and then on the upswing to 5500 rpms is when you launch the car...it takes some time to learn and get it down.
AWD cars if you dont launch on an upswing of boost you will bogg the car hard and it will fall on its face....
with AWD turbo cars...launch control is your best friend!
      05-16-2007, 10:45 AM   #10
Mrbig
106
Drives: 15 M3
Lightbulb XI
Any clue what the weight difference is on the 335i vs 335xi and any differences in trans ? Debating which is best to get !!!
      05-16-2007, 03:40 PM   #11
fedinand
fedinand's Avatar
75
335xi is about 220 pounds more.
      05-16-2007, 04:14 PM   #12
Mrbig
106
Drives: 15 M3
Question 335xi
Is that the only difference ??? Only 220lbs ??? Everything else the same......
      05-17-2007, 04:42 PM   #13
fedinand
fedinand's Avatar
75
As for differences, this was in the general section:
http://www.e90post.com/forums/showth...ighlight=335xi
      05-17-2007, 04:44 PM   #14
OpenFlash
1743
Drives: A Lot
Looks like nobody w/ a 335xi has an Exede or Procede installed. Any of the Tuners (Shiv or AA) know if their piggybacks would work on the 335xi? I would think the turbo tuner would work w/ no issues...but I'm curious about the Exede and Procede.
It should work no problem. I just haven't seen a 335xi on the road yet.
shiv
      05-17-2007, 06:20 PM   #15
CASHBY
168
shiv
saw my first one the other day on the 405.
      05-17-2007, 06:24 PM   #16
dirtyk
Drives: RDX ($aving for a 335xi)
Do you guys think the XI's driveline will be able to support Procede torque? I'm guessing it's design is pretty robust, but I don't really know what to look for (size of the driveshaft?).
      05-17-2007, 07:36 PM   #17
BoostedBMW
Moderator
BoostedBMW's Avatar
133
Drives: TiAg E92 335
2003 S2000  [0.00]
I was curious myself about it wouldnt really be great on the xi lots of grip ???
Why wouldn't it be good if you have extra grip? The idea is to put the power you make to the ground so you can accelerate faster, sitting there spinning your tires doen't do too much.
-Michael.
Berlina Black S2000 CR is now in the garage
l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l
      05-17-2007, 08:03 PM   #18
cadbimmer
BeeeeYaaaaa
Drives: 335xi
i will have my xi in about 4 weeks and a procede will be the first upgrade. im sure someone will have one by then though.
      05-17-2007, 08:15 PM   #19
Mrbig
106
Drives: 15 M3
Question XI
Anyone out there with it ??? How do you guys feel about the Xi over the rear drive car ???
      05-18-2007, 01:46 AM   #20
BMWPower06
A^M=G is nothing w/o the Power of ///M
BMWPower06's Avatar
171
Drives: ///M5 & ///M3
220lbs + Drivetrain loss from the AWD= 335i FTW
Indianapolis Red BMW ///M5
      05-18-2007, 02:55 AM   #21
bnj
14
Drives: e92 335i
Power is nothing without control. AWD is the ultimate control.
      05-18-2007, 09:50 AM   #22
cadbimmer
BeeeeYaaaaa
Drives: 335xi
i drive a legacy now with wad and i will never change to anything else. of course i live up where it snows 9 months out of the year so rwd just isnt practical. actually it was snowing this morning
