The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Quick all stock JB4 dyno run
      11-18-2011, 09:07 AM   #1
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
3131
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Map 2 all stock 335is - fuel was 4 gal of 100 octane in a full 18 gal tank of 93 octane. weather cool & raining.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      11-18-2011, 09:24 AM   #2
BAL278
BAL278's Avatar
48
Drives: E92 335xi JB
Nice!
2008 335xi Jet Black//Coral Red
VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash
Apex EC-7//Michelin PSS//Dinan CAI
      11-18-2011, 09:38 AM   #3
SteveMD
SteveMD's Avatar
198
Drives: 2016 F10 535i MSport
360 rear wheel? Nice.
Will the JB4 on a 335is produce any more power than a regular N54?
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      11-18-2011, 10:01 AM   #4
BEAR-AvHistory
3131
For bragging rights the digital readout on the dyno hit 365whp for a fraction of a second.
No once you put on the JB4 its in control of the ecu. IS still has more cooling (oil/water) then stock, more open exhaust, a few other bits & suspension pieces, 7DCT transmission but the motors are pretty much the same as the 335i.
The 335is & the JB+ are pretty close.
Kevin
      11-18-2011, 11:11 AM   #5
apocalypse
apocalypse's Avatar
14
Drives: 2021 M340i xDrive
Looks like I know what I will ask Santa for this year.
What other mods are you planning next?
      11-18-2011, 11:33 AM   #6
BEAR-AvHistory
3131
None right now. The car is limited by its tires now from a dead stop & am using 2nd gear. Maybe catted downpipes to bring into the 380whp range but that will be all...car is under warrantee & it would be a PIA to pull off a bunch of stuff for factory paid work.
Just looking for something a little extra over pure stock not the 11 second club
Kevin
      11-18-2011, 12:54 PM   #7
C-sir
C-sir's Avatar
Drives: 07 335i
      11-18-2011, 01:55 PM   #8
M340i Pride
213
Drives: 2020 BMW M340i
so JB+ on default setting 335i and 335is stock shoud be about the same? i thought jb+ default gives about 40hp and 50tq, making it 340+hp and 350 tq...
your thoughts op?
      11-18-2011, 01:58 PM   #9
Magic-Man
56
Drives: N54
Shouldn't be an issue to launch unless you just mash the gas every time
      11-18-2011, 09:43 PM   #10
chinesechicken
S3X DR1VE
chinesechicken's Avatar
Drives: 2009 E92 335i Coupe
Pair it up with a good set of DPs and you will have a bigger punch
      12-11-2011, 10:38 PM   #11
1speedbike
1speedbike's Avatar
736
Drives: 2022 X4 M40i, 2008 135i
Great dyno graph of an otherwise stock car running a JB4! Thanks, just what I was looking for
OP - you might have gotten better numbers running on map 5. Map 2 is optimized for catless DPs and I think with map 2 the timing is off compared the what you'd normally want to be running if you're without catless DPs. Map 5 would compensate for that, and even Map 1 will cause your timing to be running within good parameters considering your exhaust. Mike@N54 tuning told me running map 2 should be okay with 93 octane, an intake, and a catback exhaust, but that doesn't mean that I can get the most power out of it that way, just that it's "safe" to.
bmwpride, you'd probably have less. the JB+ adds 40-50 HP to the wheels, not to the crank. So in terms of RWHP, a stock 135/335/535 seems to have about 270-285 rwhp, depending on the car. Plus 40 horses would put it at 310-325 RWHP. Obviously, to do this, the JB+ has to add more than 40 horses at the crank, so your gains before the powertrain power loss will probably go from 300 hp to 360/370ish at the crank.
2022 X4 M40i - 2008 135i - 2015 F700GS
On Order - 2024 i4 M50
Scruffy's gonna die the way he lived... Mmhm.
      12-12-2011, 12:29 AM   #12
Kmor
Drives: e92 xi
what about with an xi with BMS DCI r u looking at the same numbers obviously with more loss to the crank?
