Understanding Gains... looking for DP's + Full Exhaust Dyno's on Stage 1 Agg Cobb
11-17-2011, 04:52 PM | #1 |
12
Rep 67
As stated I'm looking at mods and their gain potential. I really like Cobb and have it on my car so if someone could post up dyno results of dp's + full exhaust I'd appreciate it as most of the graphs have stock exhaust behind the dp's (dynojet is what I have access to here in town so that would be great).
Thank you for your help! |
11-17-2011, 05:01 PM | #2 | |
161
Rep 7,377
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-17-2011, 05:14 PM | #4 | |
74
Rep 1,309
11-17-2011, 05:39 PM | #5 |
156
Rep 3,730
You want gains?
PROcede V5 (pick your piggy) + Meth is the best bang for the buck. This alone will net you near 400 rwhp. Down the road add in DP's, FMIC, Exhaust.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
11-17-2011, 06:08 PM | #6 |
12
Rep 67
I'm trying to understand what the gains found by exhaust would be on their own with Cobb stg 1 aggressive. I had seen the dyno thread but from what I saw no one had exhaust behind their dp's but it sounds like that doesn't make a real difference anyway
11-17-2011, 06:25 PM | #8 | |
3442
Rep 79,211
For the Cobb guys hopefully they release the race maps to take advantage of methanol. I'm not sure where they are on making it public as it needs some refinement. |
11-17-2011, 06:43 PM | #9 |
51
Rep 923
On Cobb stage 1 you aren't going to get near as high of gain with the mods as you will with the Stage 2 or Stage 2+. Stage 1 is supposed to be designed for a stock car so its not going to take full advantage of the mods. Mods allow you to push the car further which in turn results in higher gains. I think DP's are the next best thing to a tune, followed by Meth. In its current form though, you will get minimal gains from Meth since Cobb isn't currently mapped to support it.
11-18-2011, 07:23 AM | #10 |
563
Rep 3,625
Bang for buck, exhaust is probably the worse mod in terms of gains for this car. Cobb doesn't even require it for their Stage 2 tune though it is recommended. At most I would think you will see around 10 hp gained but the sound is where the exhaust earns it's $.
Take a look here to get an idea of approximately what mods will net you what HP. I know this dyno was done using Procede but I think it will give you what you're looking for. http://www.extremeturbosystems.com/E...p-Dyno-Sheets/ Last edited by JStang; 11-18-2011 at 09:10 AM.. |
11-18-2011, 10:38 AM | #11 | |
12
Rep 67
