BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Should I replace the flywheel?
      11-16-2011, 01:05 AM   #1
thwgw24
thwgw24's Avatar
Taiwan
60
Drives: RB PWRED E90 N54 6MT
07' E90 335i  [0.00]
My clutch is slipping badly and will like to replace it with the ACT Street.
For those of you running aftermarket clutch, did you also replace the flywheel?
      11-16-2011, 09:31 AM   #2
jpsimon
Team Zissou
jpsimon's Avatar
3084
Drives: 2022 AWD M3 Comp - SMB
I got the SPEC lightweight aluminum flywheel with my spec clutch. their flywheel is 12 or 13lbs compared to 30+lbs stock. The car revs very quickly and its a great combo, but because of this there is clutch rattle. Nothing pressing in the clutch pedal at the stoplight can't fix but next time I do it I'll be getting something that makes less noise
      11-16-2011, 10:16 AM   #3
ar design
ar design's Avatar
297
Drives: 04 M3
How may miles are on your car?
-Critter
      11-17-2011, 03:22 PM   #4
thwgw24
thwgw24's Avatar
Taiwan
60
07' E90 335i  [0.00]
I'm at 68K.
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
      11-17-2011, 03:44 PM   #5
tscdennab
153
Drives: BMW 335i
2008 BMW  [6.24]
I think you should definitely replace the flywheel too. I am one example which replaced the clutch with another OEM one and it slips after 5k miles. I know someone that replaced the clutch with Sachs Performance and it slipped in 2k miles. The replaced with an ACT and slipped very shortly after. I think the flywheel needed to be changed.
Don't waste your ACT clutch.
      11-17-2011, 04:53 PM   #6
ar design
ar design's Avatar
297
Drives: 04 M3
Id replace it
-Critter
      11-17-2011, 08:50 PM   #7
JamesM3M5
Some dude
92
Drives: E92 335i
Id replace it
Same here. The dual-mass flywheel is not bulletproof, could be prone to failure. With the labor it takes to R/R the trans, the flywheel should be put into the budget to save headaches in the future. Especially if you're tuned.
RRT
E92 335i/6MT with stuff and things
      11-17-2011, 09:14 PM   #8
mikeith
mikeith's Avatar
35
Drives: 07 E90 335i. TiAG
why not get a 1M flywheel.... its a lot lighter too
      11-17-2011, 11:07 PM   #9
Bakeme521
Some say...
Bakeme521's Avatar
239
Drives: Fresh
2007 BMW 335i  [8.24]
8lbs? not THAT much lighter as opposed ACT which is 20lbs lighter. OP I am replacing my flywheel with the streetlite one and stg2 clutch soon. If you haven't done it yet I will let you know how it feels. With my other cars I have always replaced the flywheel, you might as well since its right there. Could save you a major headache later.
I have exhaust and an intake...
      11-18-2011, 05:20 AM   #10
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
It may not fit. There's a discussion in another thread - someone tested it with a 2006 build car and it didn't work. It may work for newer build cars, that needs to be verified though.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
