New Procede user, 335Xi Auto, stumbles at WOT low RPM
11-15-2011, 08:38 AM | #1 |
Some dude
92
Rep 1,780
FIXED: New Procede user, 335Xi Auto, stumbles at WOT low RPM
Hi all,
Have a friend with a 335Xi Auto, all stock, 29k miles. He said that the engine will cough and stumble when quickly going to WOT from low RPMs - standstill or up to about 15-20MPH. If he is rolling faster than that or rolls on the throttle moderatly fast there is no hesitation. No hesitation when in Map 0. He's coming in on Friday to get new plugs put in, still on the originals. Aside from plugs, is there anything else I should look for or change in his settings to help reduce or eliminate the stumble?
RRT
E92 335i/6MT with stuff and things Last edited by JamesM3M5; 12-03-2011 at 01:25 PM.. |
11-15-2011, 08:48 AM | #3 |
161
Rep 7,377
your friend has to log his car .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-15-2011, 09:12 AM | #4 |
46
Rep 967
Doing the plugs is a no brainer. Only took me about fifteen minutes start to finish and it got rid of all of my rough idle/high rpm misfiring issues.
Order the bosch equivalent plugs online and get the schwaben socket and you can do the whole job for well under 100 bucks.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
11-15-2011, 10:09 AM | #6 |
Some dude
92
Rep 1,780
OK thanks for the tips. I already bought a Snap On socket years ago, and I have Bosch plugs on the shelf. If the plugs don't cure it, I'll try some OL changes.
He's on the standard 7-11 or 7-29 maps (can't remember which). Not interested in the aggressive maps on this car, since he's already done with his tinkering/testing/tuning days from a past life (Honda Si turbo). This is his DD. I may be able to convince him to go further in the future...
RRT
E92 335i/6MT with stuff and things |
11-15-2011, 10:14 AM | #7 |
161
Rep 7,377
Just log the car and post them here and send logs to vishnu.
11-15-2011, 10:59 AM | #8 |
Some dude
92
Rep 1,780
Yes that will be done as well.
RRT
11-15-2011, 03:38 PM | #9 | |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Lol, sounds like traction control. Have him press the DTC button and re-test. |
11-15-2011, 03:54 PM | #10 | |
17
Rep 205
For what it's worth, the aggressive maps were trying to push 16 psi on my completely stock car, and that's typically when the misfires happened. Going back to 7-29 maps it never exceeds 14psi and I don't see the misfires anymore. |
11-15-2011, 03:58 PM | #11 |
3442
Rep 79,211
More boost doesnt necessarily cause misfires.
You should read into the misfires. Are they 1 cyldiner or multiple cylinders? Spark plugs, fuel injectors, bad coils, or even fuel pump problems can cause misfires. I dont know how many more threads we can have about misfires so here it is for people to search. Hesitation bad idle rough not smooth cold start misfires plugs spark problem search injectors fuel pump coil packs replace Last edited by Jeff@TopGearSolutions; 11-15-2011 at 04:07 PM.. |
11-15-2011, 04:04 PM | #12 |
17
Rep 205
More boost doesn't necessarily cause misfires, sure, but you can't keep increasing boost indefinitely and not expect some symptoms.
It appears to just be Cylinder 2. |
11-15-2011, 04:08 PM | #13 | |
3442
Rep 79,211
Logs would also determine what is going on. I dont condone raising boost indefinitely, not sure where i said that. |
11-15-2011, 04:19 PM | #14 | |
1750
Rep 17,960
Drives: A Lot
Again, this doesn't seem to be the case with the OP as he isn't throwing any misfire codes. Just the normal hesitation that one would expect to see when romping on it at low speed with traction control not disabled. Shiv |
11-15-2011, 06:40 PM | #15 | |
17
Rep 205
11-15-2011, 06:45 PM | #16 |
78
Rep 1,883
Injectors starting to go bad can cause those type of symptoms. When they start to go bad, it is easier to produce the symptoms at higher boost. Went through this process for every one of my injectors one by one. Not fun.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
11-15-2011, 07:02 PM | #17 |
1750
Rep 17,960
Drives: A Lot
If what you are feeling isn't traction control kicking in, the next thing I would try is new spark plugs if they havent been changed in the last 20k miles. That's far more likely the cause than injector issues (although there are recalls pending right now). Best bet would be to call your dealership, tell them your VIN and ask them if any apply to your car.
12-03-2011, 01:31 PM | #18 |
Some dude
92
Rep 1,780
Problem solved:
No, new plugs did not fix it, nor was it traction control. Reset all adaptations and ECU. No better. Logged, found knock induced timing pulls at 2000-2800 RPM when whacking the throttle open from a standstill/slow roll. 2-3 hard hesitations until you got past 3k. I tried pulling timing in the affected cells by up to 5 degrees, no help. It was anywhere from 0 to +2 in those cells, I went to up to -5. So I called Vishnu and got Robert. He told me to change to the 11-1 map. Since this car has NO other mods, I put on Stage 1 6AT. Reset all adaptations. Test drove. PROBLEM FIXED. Evidently the 11-1 maps control timing a little differently per Robert. Thanks to Vishnu and Robert. Phone answered immediately, and gave me the tip as soon as I told him the problem and my current diagnostic and repair attempts.
RRT
12-03-2011, 05:59 PM | #19 | |
17
Rep 205
