Scoops!
11-14-2011, 11:02 PM | #2 |
149
Rep 6,604
Drives: e92 335i
don't need to you can do it on a stock car too
11-14-2011, 11:52 PM | #3 |
Rep 102
[QUOTE=josh06lau;10804500]don't need to you can do it on a stock car too[/QUOTE
Oh koo thanks! So how what are they connected to or how do u install? |
11-15-2011, 12:53 PM | #4 |
30
Rep 501
scoop just add more air flow to your intake systems, It add more air flow when you are driving 70mph++, but if you want to add scoop for looks, just go for it.
to install, just remove your oem air scoop cover, then drop your new "scoop", its an easy install, took me around 15 min. Search for some DIY according to your type of scoop. |
11-15-2011, 02:20 PM | #5 | |
Team iTouge
121
Rep 2,101
If you want, I can install it for 10 bucks it'd only take around 10 minutes max
11-15-2011, 03:07 PM | #7 | |
Team iTouge
121
Rep 2,101
Sorta true, not completely though. If you are going to just get it for normal driving yes. If you race with it or climb hills or on the freeway a lot then no. Scoops give more of a throttle response when paired with the k&n drop in filter. And you don't need to go 70++ mph to feel a difference, only over 30 mph. Your throttle response will be there if you are cruising or rolling already but if barely starting out the car will lag as usual. Cyba has cheap and good ones and its a lot cheaper than rpi or afe and has rain holes so watcer can get out instead of going into your filter
11-15-2011, 03:15 PM | #8 | |
231
Rep 1,473
The money is better spent elsewhere. |
11-15-2011, 03:35 PM | #9 |
21
Rep 549
Just for looks really.....any performance gains for normal driving is just going to be negligible. But nothing wrong with cosmetic mods right...?
11-15-2011, 03:58 PM | #10 | |
Team iTouge
121
Rep 2,101
+1 its not major as a new boost kit but still nice to have and I feel the difference in the mountains
11-15-2011, 04:04 PM | #11 | |
Team iTouge
121
Rep 2,101
Beg to differ on cooling the radiator, I haven't once had an heat problems after installing the scoops, id be more than glad to give you a quick ride if you are around long beach for the meet or something. They aren't magnificent but they do the job in throttle input when you are going up hill, as I said they won't be a great investment if you are driving normally, unless you are going for the look. As far as actually tracking I m not too sure about how great it'd be but like I said id give you a free quick ride if you come to the 562 meet next month. Search it on youtube, it acts as a ram air intake. Its like cars with a turbo kit that has a funnel for direct air into the turbine. Its not too different from what you see on some drag racing cars.
11-20-2011, 05:51 PM | #12 |
11
Rep 569
Stangorang and kiwi29 are wasting each others time talking about scoops being effective in any case. Also, you two drive different cars, 335i>328i....yet the OP is asking about scoops for his 06 325i ....
As a side note, who offers to give a 'free ride' to show how an addition of scoops makes an improvement on your naturally aspired engine's throttle response?? But really...just search around the forum and see if you can find dyno sheets showing an improvement in engine performance with just the addition of scoops. <-This topic has been and we should just focus on what the OP has asked. |
11-21-2011, 03:55 AM | #13 | ||
Team iTouge
121
Rep 2,101
11-21-2011, 12:10 PM | #14 |
See Me Fly By In A 330i
55
Rep 255
Drives: AlpineWhite 330i 6-speed
i agree scoops aren't always the best idea..but to each there own, i personal think dinans ram air is the best way to get air in
http://www.dinancars.com/shop/D760-9...ly.aspx#page=1
E90 330I
12-29-2011, 03:42 AM | #15 | |
Rep 7
12-29-2011, 08:42 AM | #16 | |
141
Rep 2,217
