MISFIRES!!!
11-14-2011, 12:08 PM | #1 |
23
Rep 122
MISFIRES!!!
Last week I found out I had a micro crack in valve cover and it was spurting oil onto the spark plugs which was causing the misfires.... after installing a new valve cover and gasket , changing the ignition coils as well with the spark plugs and cleaning the oil with break cleaner I thought it was fixed... today during a cold start it was a very rough start and have really bad stuttering and shaking trying to reverse out of my drive.... begin to drive and misfire at 2800 rpm not even 25 percent throttle 2 mins into the drive... Help please
COBB PROTUNE/HFS4/AFE STG 2 DCI/ BMS OCC/AR 3" C*tless DPs/ER CP/Forge DV's/ Eibach Pro springs/M3 suspension bits/CF rear diffuser/ 30% tints / Lightly smoked tails/ Blacked out grill /SSP clutches
11-14-2011, 12:27 PM | #4 |
23
Rep 122
scanned the car... prior to getting the valve cover replaced.... misfires in cyl # 3,4,5 this was because of the oil...I also got a random throttle body angle code... cleared everything and scanned it again misfire only in cyl 5.... I run 80-20 meth and 94 sunoco gas... I also have a gut feeling my hpfp is on the fritz.... side note... when the car is warmed up runs very well although I'm undering boosting in map 3 peak only to 15.8psi.
11-14-2011, 01:41 PM | #6 |
51
Rep 923
11-14-2011, 02:40 PM | #7 |
161
Rep 7,377
and you need a new injector gasket - oring or whatever is called as well otherwise you will leak pressure.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-14-2011, 02:55 PM | #8 |
Mad Linux Guru On The Loose
1130
Rep 5,404
Drives: 2008 335i Sedan, 2023 M3
Lovely advice! You should be ashamed!
