Cobb or GIAC, can you do something about this ?
11-13-2011, 06:07 PM | #1 |
153
Rep 1,809
It's about the shift bog on manual transmission cars. Again. Since this problem has not really been solved until now, I want to keep some interest on it with (perhaps) some new information. I am sick of ruining 50-60% of my drag strip runs because of the shift bog.
I don't expect any piggyback manufacturer to be able to do something about it, because I think it's a mechanism from the ECU software. This could only be solved by altering the software. The picture below is a magnification of a 3-4 bog event. As you can see, the ECU demands that the boost to rise slowly after the shift (look at the target boost mild slope !). The throttle blade only acts to control boost until the actual boost drops under the boost target, after which it opens fully, but the boost continues to climb slowly on a mild slope set by the ECU. Since I have been able to induce bog when my car was stock, I believe that it is a protection mechanism. I wonder if any flash tuner is able to alter this piece of software from the ECU ? |
11-13-2011, 06:27 PM | #2 |
Mad Linux Guru On The Loose
1130
Rep 5,404
Drives: 2008 335i Sedan, 2023 M3
I would not be surprised if BMW purposefully did this to limit the amount of shock various drive train components are exposed to from the all-mighty N54. This is the reason why they put the notorious clutch delay valve.
I agree though, the shift bog would be nice to be coded out or at least, its effects reduced.
11-13-2011, 08:08 PM | #5 |
102
Rep 1,903
Drives: e92 335i 6MT
I cant say that I've ever felt the shift bog w/ Cobb...I mean is it actually noticeable without looking at the data? I think the no lift shift feature would help maintain higher boost levels between shifts
11-13-2011, 11:09 PM | #6 | |
55
Rep 495
GIAC stage II|AA DP|AA Charge pipe and BOV|AFE S2 Intake|HELIX FMIC
11-14-2011, 03:27 AM | #7 |
263
Rep 2,563
I can also feel that on a regular basis. GIAC stage 2 with MT here.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
11-14-2011, 10:14 AM | #8 |
1130
Rep 5,404
Yes, it is there with and without Cobb. I've felt it with GIAC as well.
11-14-2011, 01:53 PM | #9 |
113
Rep 4,771
11-14-2011, 02:56 PM | #10 | |
1130
Rep 5,404
What ISTA version does he have?
11-14-2011, 03:42 PM | #11 |
153
Rep 1,809
I know multiple people with GIAC/JB4/Procede who have the shift bog. It's not your car...
I have sent detailed logs to Austin @ GIAC and he said they will take a look to see what's happening. Hopefully they can find a solution. If there is someone who has the means to solve it, I think GIAC is the one. I think they are the most advanced with N54 software reverse engineering right now. I will post here if I receive interesting information. |
11-14-2011, 04:11 PM | #12 |
55
Rep 495
CDV does not resolve this issue. I think the car just kills the boost on shift
the higher the rpm the more boost lag is felt.
11-14-2011, 10:10 PM | #15 |
27
Rep 1,410
It is definitely there. I have it on my car... stock, SSTT, and even with different versions/stages of COBB now. It is really bad from 3rd to 4th for some reason. I know I lose some eta/mph on a drag run because of it, but there doesn't seem to be any way to solve the problem.
Zeph |
11-14-2011, 10:52 PM | #16 |
153
Rep 1,809
I received a very encouraging answer from Austin@GIAC !
"Hi Catalin, From the logs that you have sent over, it seems like you are triggering the clutch/transmission protection safeties in the DME. This is something that can be removed, however, it is likely to shorten the life of your clutch significantly." Austin asked for some more logging, however. This leads me to believe that with a slipping clutch (subtle slipping and not knowing it), this can happen more often. If I can remove this, I will. GIAC would gain a lot of customers if they could remove this |
11-15-2011, 12:29 AM | #17 |
73
Rep 978
11-15-2011, 01:05 AM | #18 | |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
11-15-2011, 04:27 AM | #19 | |
153
Rep 1,809
It MAY happen more often with a slipping clutch. This is just my supposition. And it really is a huge deal, just search the forums for "bog". |
11-15-2011, 06:04 AM | #20 | |
153
Rep 1,809
http://www.e90post.com/forums/showpo...13&postcount=6 |
11-15-2011, 10:09 AM | #22 |
27
Rep 1,410
I like the idea that the clutch is seeing slippage and that is why the bog occurs. I was planning to upgrade my clutch soon anyway and I was hoping/wishing this would fix the issue in case it was related to slip. Maybe it happens more on the 3-4 shift since by then things are heated up much more as this is the last shift during a drag race. I know HPF concluded that it was possibly a slippage issue in another thread... of course that was a thread where they were trying to sell their new clutch so you have to take that information with a grain of salt.
On the other hand, I didn't realize DME's/ECU's even had that type of ability to detect MT clutch slippage and lower power to compensate... but definitely possible! Zeph |
