TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > My car wont run Cobb stage 2+.
      11-13-2011, 05:20 PM   #1
aramsey80
Drives: 2009 135i
Like the tittle says. It starts misfiring at WOT. I switch to the regular stage 2 map and it runs fine. Any ideas? It threw a misfire code on #6 cylinder. The car is a 07 6at. Hpf intercooler, Bms intake and cpe downpipes.
      11-13-2011, 05:21 PM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
how old are your plugs?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      11-13-2011, 05:29 PM   #3
mithiral67
That guy
mithiral67's Avatar
117
Drives: 2015 Cayman GTS
my car did the same thing. New plugs fixed it.
      11-13-2011, 05:50 PM   #4
aramsey80
Drives: 2009 135i
Not sure bought the car used. 38k miles. I will change them and see. Thanks.
      11-13-2011, 05:55 PM   #5
tofu-
87
Drives: 335i Jet Black/Coral Red
I had the same problem on a different tune. Was my ignition coil. So yeah, check both
      11-13-2011, 06:06 PM   #6
mithiral67
That guy
mithiral67's Avatar
117
yea, my car has 36k (i bought new) with 2 hpfps, new injecters under recalls and standard maintenance and they never changed my plugs.
      11-13-2011, 06:06 PM   #7
JStang
JStang's Avatar
563
Drives: FDB M3 CS
With 38k you are likely on the original plugs. I would bet that is the issue.
      11-13-2011, 06:23 PM   #8
Bakeme521
Some say...
Bakeme521's Avatar
239
Drives: Fresh
2007 BMW 335i  [8.24]
had the same problem, had one bad coil. Changed it and it was fixed.
On a side note, do you feel strange throttle oscillations when putting it to the floor?
I have exhaust and an intake...
      11-13-2011, 06:37 PM   #9
mithiral67
That guy
mithiral67's Avatar
117
Thats a known issue that cobb is working on.
      11-13-2011, 07:43 PM   #10
ducati955
ducati955's Avatar
90
Drives: lifted tacoma on 38's & ducati
2007 BMW 335i  [10.00]
throttle oscillations? what exactly does that mean?
car totaled out !!AW335i, oem aero lip, m3 csl rims, oem m3 sides, vorst csl carbon trunk, tinted, lowered on H&R sport, AR DP's, Bastauck dual exhaust, BMS intake, etc
NEW RIDE white GTR!
      11-13-2011, 07:55 PM   #11
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Same thing here...cylinder 6 misfires at WOT on S2+. Original plugs with 35k miles. Plugs will be changed next week. Hopefully, that will fix it. No issues running S1
      11-13-2011, 08:50 PM   #12
Pseudo Nim
twinborific
Pseudo Nim's Avatar
119
Drives: fast, sometimes slow
If your car is still under warranty, did you just bring it to the dealer with the tune installed and the code thrown? Or did you pay for a plug change? Since there is no way to throw the misfire on stock/stg1/stg2, any idea if the load placed on the plugs will EVENTUALLY manifest itself on the stock map so that it can be warrantied?
Doko ni itemo, hito wa tsunagatte iru...
      11-13-2011, 09:47 PM   #13
nitehawk
nitehawk's Avatar
102
It will, but honestly you may be waiting forever. Buy the plugs online, and get it out of the way for less than $100
      11-13-2011, 09:57 PM   #14
Pseudo Nim
twinborific
Pseudo Nim's Avatar
119
I see - that's definitely not expensive. what if it's the coils tho
      11-13-2011, 10:03 PM   #15
nitehawk
nitehawk's Avatar
102
Well, I think its good practice to start with a fresh set of plugs as soon as you start running a tune - as you would have to change them out later anyway. If the problem still persists, then you can start looking at coils
      11-14-2011, 01:41 PM   #16
Brey335i
113
Drives: e46 ///M3
A fresh set of plugs is never a bad idea
      11-14-2011, 02:24 PM   #17
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
821
Drives: Independent Tuning Specialists
I'm with everyone else, first thing we look at on our 335i when she miss fires is the plugs.
ECS Tuning
      11-15-2011, 10:22 AM   #18
aramsey80
Drives: 2009 135i
Changed the plugs and the car runs great!! Thanks.
      11-15-2011, 11:13 AM   #19
Bakeme521
Some say...
Bakeme521's Avatar
239
Drives: Fresh
Yes and no, I contacted them and they told me to check my DCI b/c they have seen that happen with DCI with the air filter on too far, that's all they really had to tell me about it. I have talked about it on another forum and only some are feeling it, not everyone running stg 2+ is.
      11-15-2011, 02:34 PM   #20
335TWNTURBO
54
Drives: 07 335i
+1
