Agressive maps...Wastegate DC% I need some help
11-13-2011, 04:31 PM | #1 |
442
Rep 18,331
Can someone log wastegate DC% for me with these new Procede aggressive maps that has a AT...I want to know if the DC% returns back to idle postion of 60.2 after half throttle or WOT and then letting off the gas or does it get stuck at 32.8 OCCASIONALLY!...7-11 maps work fine and never EXHIBITS this strange wastegate duty cycle reading for me but the 7-29 and 11-3 maps for some reason the wastegate DC% occasionally gets stuck at 32.8 when I am at idle and I need to stab at the throttle to get it back to 60.2 Please dont tell me that my wastegates are stuck because 7-11 maps work fine and so do the 12-17 maps and it NEVER happens...I want to know if it has something to do with my DME software...I am running still 27.xx! Please let me know guys.. I want to run these aggressive maps but for some reason 7-29 and 11-3 makes my wastegates a little erratic...So what I want to know is if this is normal and its just me or it has something to do with my software DME which is mad old! 27.xx FTW Reason I dont want to change over is because the new software from what I heard and see creates a post shift timing flatline drops which to this day none of the tuners or Cobb has figured out...I dont have this occuring with my car with timing flatlines, so it has something to do for sure with the latest BMW software...Someone please help me as I have help many on this forum that needed some help. All I need is for someone with old software to log the wastegate DC% and see if sometimes it gets stuck at 32.8 during idle and I want other that have new software to also do this for me..
11-13-2011, 04:45 PM | #2 |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Does it really matter what your wastegate DC% is at idle? Depending on dme software version, a stock car runs anywhere between 11 and 80%. And then it changes after prolonged period of idle presumably to recharge/discharge the vacuum tank.
I can provide a log on tues when I get back to the office. All you want is a log of prolonged idle?? Last edited by OpenFlash; 11-13-2011 at 04:53 PM.. |
11-13-2011, 04:53 PM | #3 | |
442
Rep 18,331
If duty cycle is not at 60.2, the car doesnt seem to boost right upon the next throttle modulation and the car sounds different (exhaust tone) I can tell the difference for sure after....I dont even need to do a complete run to show this weird behavior of the wastegates being at 32.8 What I need to know is anyone else experiencing this... |
11-13-2011, 06:30 PM | #4 |
65
Rep 1,708
I think there should be a rule that if you ask for logs you should display logs first. I personally have only noticed wgdc at setpoint when at idle. DC will match table/pid once dme throttle reaches certain point... Not sure what this is but seems to be around 20ish %
11-13-2011, 06:33 PM | #5 | |
1750
Rep 17,960
Drives: A Lot
11-13-2011, 06:55 PM | #6 | |
442
Rep 18,331
7-11 and 12-17 it always goes back to 60.2 and normal boosting upon next throttle modulation...These maps (7-29, 11-3) something has changed which creates this issue with my car.. There is nothing wrong with my solenoids or wastegates either because it would exhibit this on all maps, so please dont say its hardware related! I am running the oldest software 27.xx! Last edited by cn555ic; 11-13-2011 at 07:02 PM.. |
11-13-2011, 07:07 PM | #7 |
1750
Rep 17,960
Drives: A Lot
We understand what you are saying. But what is the problem with wg dc% not being what you feel it should be at idle/cruise? Is there a problem with this? Does the lower dc% cause wastegate rattle?
11-13-2011, 08:04 PM | #8 | |
442
Rep 18,331
When this happens with the wg dc at 32.8, as soon as you take off on the car there is like a hesitation and the car is not able to boost correctly as it would when it is at 60.2 at idle, but when the times it does revert back to 60.2 the car runs normal upon next throttle modulation...If the car ran fine I could care less what wg dc is at idle...I have been troubleshooting this wastegate issues for a while now which lead me to check it so often and look at that channel!! Started with the farting of solenoids (changed to a new one) but that wasnt the solution, wastegates clicking back and forth which I though it was my wastegates getting stuck and that turned out to not be the issue...All my issues stems from the Procede maps and firmware that for some strange reason is not compatible with my car!! I am not blaming anything on the Procede as many softwares are sometimes not compatible at all....For Some reason only the 12-17 and 7-11 maps work flawlessly with my car and others dont...12-17 and 11-3 does not exhibit these issues I speak off at all. I beat on it all day and when I come to idle the wg dc is back at 60.2 which is what I see on the logs of people using other maps that dont work on my car..All other maps including dic maps in february 2-20, 3-30 and the ones in May, 7-29, 11-3... Maps 12-17 and 7-11 work perfect...Something has changed in the firmware to cause this...Is it possible to work out a aggressive map using 7-11 logic of controlling the wastegates? And all those maps I speak of that dont work with my car, upon deceleration there is noticeable wastegate rattle.. Shiv please look at all your logs you have compiled from people sending you thousands of logs, and you tell me once do you see any other cars after a run the wg dc value at 32.8 at idle! Your not going to find one. I am not tripping and bugging out because I have done my research on other peoples logs and some of yours, and none of them show this, except for the few that had weird issues which reverting back to 7-11 solved it for them. Something has changed you would know better than me, but all I am asking is a 7-11 based map that has all the aggressive behavior of the 11-3 maps. . Last edited by cn555ic; 11-13-2011 at 08:16 PM.. |
11-14-2011, 07:01 AM | #11 |
161
Rep 7,377
i can check mine tonight and upload some.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-14-2011, 07:03 AM | #12 |
40
Rep 957
when im off throttle im back to 60.2. these two logs are with older 107 firmware and 7-11 or 7-29 maps.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
11-14-2011, 07:12 AM | #13 |
40
Rep 957
Heres one more. with 7-11 maps here... I dont have any 109 firmware/aggressive map logs with wastegate dc recorded so if no one posts one, ill go log one.
11-14-2011, 12:18 PM | #16 |
40
Rep 957
i go out ti fire up car and im getting half engine light in dash and car is reving itself. here we go again. i didnt touch anything lol .
11-14-2011, 12:22 PM | #17 |
3442
Rep 79,211
11-14-2011, 01:23 PM | #18 |
161
Rep 7,377
here you go 60.2 at let off
11-14-2011, 02:10 PM | #19 |
69
Rep 1,943
Check out my thread. Look the second Log maps 11-01 at idle for awhile
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-14-2011, 02:55 PM | #20 |
442
Rep 18,331
Thanks Enrita..Like I said it goes to 60.2 at idle as its the norm but Shiv is telling me its not! Other maps I used that work with mycar 7-11 and 12-17 the wg DC always has a value of 60.2 at idle, whereas the other ones including the newest aggressive maps dont...I am asking for some support here but it seems that I am told its normal but from what people have posted the norm is 60.2 at idle
11-14-2011, 02:55 PM | #21 |
442
Rep 18,331
11-14-2011, 06:31 PM | #22 |
442
Rep 18,331
I guess I have to load up the damn maps and log it for the world to see that I Am not loosing my mind and indeed this is happening. Every log I see the wastegates after a run returns back to 60.2 and Shiv knows this. I want someone to show me a log otherwise. It ain't happening.
