How to clean and lube cup holders?
05-11-2007, 04:14 AM | #1 |
Rep 2
Drives: 2006 330xi
I realize I must have spilled a few drops of coffee over time but no spills. The cup holder starts to move out then stops until you give a little pull to help it out. I was considering cleaning it by spraying simple green in the spaces and after drying spay silicone with the straw tip on the can . Anyone have any luck lubing these poorly designed cup holders. TIA
05-11-2007, 04:21 AM | #2 |
294
Rep 2,414
Drives: E92 335i
Order a new one from dealer.
05-11-2007, 07:35 AM | #3 |
550
Rep 6,563
see if dealer will replace it for you for free of charge. Some dealer will do that just to get brownies points. Why not give it a try.
under construction! |
05-11-2007, 11:08 AM | #4 |
26
Rep 1,826
Drives: E92 335i
I had this same problem when I took delivery -- there was actually a defect in the cupholder trim that prevented the mechanism from operating freely. It was replaced under warranty.
If you actually just gummed it up, there's a writeup in the DIY section for removing the assembly. IIRC you just pop off the trim panel around the cupholders and each holder is attached to the dash with a couple screws. |
05-17-2007, 12:44 PM | #5 |
39
Rep 709
Drives: '07 335i (E93)
Those cupholders should be outlawed...they're the worst designed things. BMW does most everything so well, and yet they give us these flimsy rattle makers...
Rant over...
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word. |
05-22-2007, 01:42 PM | #6 | |
83
Rep 1,208
But would def like to know how to better clean them. Mine is as good as new still, but when it does get dirty i would like to know how to clean it.
05-22-2007, 03:12 PM | #7 |
39
Rep 709
I didn't say they weren't a good idea...just that they need to be designed better. Good location, yes. Don't take up much space, yes. Rattle and chatter a lot, YES!
05-24-2007, 10:51 AM | #8 |
is it the 5oclock free crack giveaway?
234
Rep 17,453
yea the passenger one just decided to crap out. i cleaned it a bit, buts it not as free moving as the driver's side. think its time to get a new one under warranty
05-26-2007, 10:39 AM | #9 |
Rep 182
Drives: 2008 335i coupe, montego blue,
Garage List 2008 e92 335i coupe [0.00]
2008 335i coupe [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] |
Wow! I use mine all the time and have not had any problem, if I spill coffee then I clean it up although I haven't a spill on the inside. I like the design because it tucks away when not in use. I do think the execution could have been done better.
