Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Help!! Shaky steering wheel during acceleration
      11-10-2011, 08:16 AM   #1
tilua
19
Drives: 2008 335i convertible
I've posted this on X5 forum but afraid I won't get any response so figure I'd post it here in case some of y'all might have experience with X5.
I bought a 2001 X5 a couple of years ago and we have replaced a few suspension parts in the past. Air spring in the back to the control arm in the front, etc.
However recently we've been experiencing the steering wheel shakes violently during medium to strong acceleration. I've checked all the bushing and they seem to be in good shape.
Before I bring it to the shop or do it myself, I want to get some feed back from you guys what to expect and to see if anyone ran in to this problem before.
Thanks,
tilua
      11-10-2011, 12:44 PM   #2
moar
moar's Avatar
14
Drives: 330i
Wheel balancing.
2007 330i M Sport Saloon Le Mans Blue
Active steering - Comfort Access - Bluetooth -TV - Heated Electric Memory Leather Seats - Auto - Logic 7 - Pro Nav - Adaptive Xenon Headlights
BMW Assist - iPod integration - Swirl free
      11-10-2011, 01:04 PM   #3
Tom K.
Tom K.'s Avatar
124
Drives: '07 328iT, '13 Boxster
Originally Posted by moar View Post
Wheel balancing.
Causes shaking at certain speeds (usually around 60~70mph), but not on acceleration.
Tom
      11-10-2011, 01:13 PM   #4
moar
moar's Avatar
14
Drives: 330i
It can cause it on acceleration as it can be alot more noticeable, especially on hard acceleration.
Shaking can be anywhere from 40-70.
Definitely a good cheap place to start.
      11-10-2011, 01:46 PM   #5
tilua
19
It's definitely not the wheels since I just got them balanced and it doesn't shake when traveling anywhere from 0-90mph with out accelerating. So far im thinking of the CV joint/axel.
      11-10-2011, 05:39 PM   #6
e90pilot
Freight Dawg
e90pilot's Avatar
104
Drives: E90 325i
CV joints rattle when you turn but if it's a bent axel it would shake but also it would pull to one side. Check all the bushings. Worn bushings cause the wheel to shake but it wouldn't be only on throttle. Strange.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      11-11-2011, 12:31 PM   #7
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
A worn drive shaft center support bearing can cause the car to shake under hard acceleration.
      11-13-2011, 12:19 AM   #8
Glim
21
Drives: 2006 330i & 2013 X5 35i
Check your lug nuts are at 88 ft lbs
      11-13-2011, 09:23 AM   #9
fdriller9
253
Drives: '06 AW 330xi
2006 330xi  [6.44]
Do you have another set of wheels you can try mounting up?
A bent wheel can balance perfectly on the machine but the bends can cause vibrations throughout the chassis.
If you're on a square setup, try moving the fronts to the back. The vibration won't be felt as much in the steering wheel but the vibrations will cause premature wear on your other suspension components.
      11-20-2011, 12:01 PM   #10
medusacomp
Drives: 328xi
lower control arm bushings!! i just changed mine and they where both broken, shaking is gone!!
