Turbos Went South...
11-09-2011, 11:50 PM | #1 |
Rep 12
Getting the death siren even when my oil temp is 230 degrees now... (although its faint).
So I've been putting around in procede N/A mode trying to decide what me next move is going to be. I've found a site that does TD03 rebuilds for cheap, but i can't have my car out of service for that long. How are e-bay turbos? Is my best bet just to surf the for sale section until something pops up? I can do the install myself (best bud owns his own shop), but I'm trying to keep this whole thing under wraps from the wife so I'm wondering if I can take care of it for under 1 grand? Just for kicks... how hard would it be to build my own upgraded snails? I was thinking of picking up some cheapies off e-bay and working a connection I have with a machinist and seeing if I can do my own snail upgrade... |
11-10-2011, 01:26 AM | #2 |
26
Rep 660
eBay turbos for 335?
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
11-10-2011, 02:32 AM | #3 |
51
Rep 923
I'm afraid its not as easy as buying "e-bay turbos" and swapping them out on this car. If it was everyone would be running upgraded turbos. You can try to go that route, but you will be throwing your money away. You may be able to find a used OEM set from another member that upgraded their turbos. That would be your best bet to stay within your budget. If labor is free then you may be able to get away for about a grand.
11-10-2011, 02:35 AM | #4 |
161
Rep 7,377
you should get them upgraded since you are there.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-10-2011, 07:44 AM | #6 |
1843
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
Tischer has OEM turbos at a reasonable price - check getbmwparts.com.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
11-10-2011, 10:13 AM | #7 |
156
Rep 3,730
Rob Beck turbos to bring them back North again
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
11-10-2011, 10:35 AM | #9 |
Rep 12
Thanks guys I'll look into the tischer option.
Honestly though these things are so easy to rebuild why shouldn't I just buy a rebuilt kit and swap out all the bearings/seals for a couple hundred? I mean... the bearings being "cooked" (or otherwise heavily worn) are the cause for the whine correct? Edit - Also, the whine is hardly noticeable at operating temp, but only at 1-2k RPM. You'd only notice it if you're looking for it. Note, however, this isn't the usual turbo spooling noise which I've become quite acquainted with It's definitely the siren, it just isn't quite as bad when they're fully warm. |
11-10-2011, 11:05 AM | #10 |
Joint Chiefs of Staff
4927
Rep 116,037
11-10-2011, 11:50 AM | #11 |
I even mod my cereal
249
Rep 3,445
Drives: 11 ZCP DCT M3 14 328d 21 GT4
+1....great price right now.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser, Neodyme GT3 Wheel Color |
11-10-2011, 11:57 AM | #12 |
172
Rep 1,267
I would just rebuild them why spend the extra money if you don't have to.
I am guessing your car is out of warranty?
08 AW 6MT | MHD | Wavetrac LSD 3.46 | AE Quad | VRSF DP'S | VRSF 7" IC | DD Hood / Diffuser| Mtech Front / Rear| BMW Performance Splitters / Spoiler | Wheels 18lb 18x9 SQ | Hexon RR550 | TFT Inlets |
11-10-2011, 03:25 PM | #13 |
161
Rep 3,736
+1, are you still building boost or noticing any drop off in performance?, if not don't worry yet..
11-11-2011, 09:50 AM | #14 |
147
Rep 2,608
Drives: G80 Comp XDrive
Mine have been making that sound for the past year, still holding boost though so I'm still beating on them till they stop
11-12-2011, 09:50 AM | #16 |
74
Rep 1,543
11-12-2011, 11:46 AM | #17 |
3442
Rep 79,211
Are you sure they are done? Cause I've had the "siren" since day 1 out of the dealer and I still maintain full boost, no blue smoke out the exhaust, ETC
I wouldnt count your chickens until they actually hatch. |
11-12-2011, 09:18 PM | #18 |
Rep 19
jubb,
There is manufacturing defect on some of the turbos on some N54 engine platforms. My friend had both of them replaced under warranty just 2 months ago. I would search around regarding that matter. Then try getting it fixed at the dealer. Good Luck bro. Let us know how it turns out. |
11-13-2011, 12:55 AM | #19 | |
2097
Rep 43,350
Turbos are supposed to make noise, especially if you don't have the factory air cleaner installed. There's a reason they refer to that assembly as a "silencing" unit If you're building adequate boost and not blowing blue smoke, you don't need new turbos. |
11-13-2011, 07:06 AM | #20 |
112
Rep 2,856
Drives: 2011 335is E93
Here's a question....
Has Rob finished with his upgraded turbo project? What do hp/trq numbers look like if so? And how much? Also, does anyone know that the N54 can really handle power numbers in the 500's with stock internals? I remember hearing that these engines come with forged internals, is this correct? If so, how reliable will the higher power be and for how long? I'd be worried about durability.... |
