At Start At 1/4 Mile?
11-09-2011, 12:12 PM | #1 |
Rep 31
Going to the track this weekend... which have you seen is better, starting in 2nd gear or 1st???
Thanks.
Mods: JB4 G5 / Dinan Stage 2, Intake, AFE scoops, DP´s, Dinan oil cooler.
11-09-2011, 02:22 PM | #5 |
30
Rep 314
Drives: 07 BMW 335i Sedan+2 Baby Seats
if you have drag tire setup and can heat them up ... 1st gear.
if you have a street tire setup, 2nd gear. Junk
11.535@124.423mph (1.641 60') - AutoTune 7-27, Race+Meth, Best ET w/ only 80% throttle 1st and 2nd
11.647@121.356mph (1.590 60') - AutoTune (beta pre-5-15), Race Gas, No METH Perf Mods: Vishnu PROcede Rev3 v5, Vishnu PWM Meth Kit, AR Design DPs, AE Exhaust, Helix FMIC, Vishnu DCI, Forge DV, WaveTrac LSD (Best Trap - 124.665mph) |
11-09-2011, 03:36 PM | #6 | |
279
Rep 5,063
Drives: Black e92 335i
Exactlyyyy
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
11-09-2011, 03:55 PM | #7 |
3437
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
What chip do you have? Some like the Proceed have traction control features that enable first gear launches, even with 400+ RWHP. The chip reduces torque at the milisecond level to enable traction, which works much differently than the factory DTC which applies the brakes and slows you down. I launch in 1st but short shift at around 3,500 RPM into 2nd for the best results on my car.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
11-09-2011, 07:04 PM | #9 |
3437
Rep 6,771
Drives: 2016 BMW i8
If you are asking me (vs the OP), I do not. In fact, I probably push the pedal 3/4 of the way down to get the best launch, and manually short shift on the paddle shifters around 3,500/4,000 rpm.
11-10-2011, 12:27 PM | #11 |
156
Rep 3,730
Brake boost and launch in 2nd for most consistant runs. You will also have 1 less gear to shift into when launching in 2nd. Hotrod did some testing - 1st gear launch = better 0-60. 2nd gear launch = better 1/4 mile.
If you are flooring it in 1st....you are just going to sit there and spin. Anything more than 1/2 throttle is almost too much in 1st.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
11-10-2011, 12:31 PM | #13 |
156
Rep 3,730
I have my kickdown switch "disabled". I beleive 78% throttle position = 100% throttle.
11-10-2011, 02:44 PM | #14 |
125
Rep 2,172
If you read the other threads about making a spacer to put under the peddle, don't bother. The peddle has a ball and socket connection on the shaft, just pull on it and it will come out. Then you can put rubber washers or spacers over the shaft. Then snap the ball and socket back together and test it. You may need to add more to get it shimmed out, but it makes a world of differance. Nothing worse than a hard pull in 3rd only to have it kick down to 2nd with over 400 rwhp. Try that some day while turning a corner and see how quick you can get out of it. LOL
Once you have it so it doesn't kick down, hook your laptop up and log some data to make sure your able to get to WOT. BTW, your AT will still kick down in D or DS, but in M it will not. Have fun. |
