EVOLUTION RACEWERKS | Introducing Our Competition Series Dual Oil Coolers
11-08-2011, 06:17 PM | #1 |
140
Rep 863
Hello fellow e90post users, my name is John (some of you might know me as Jz) and I am now an official sponsor of e90post with Evolution Racewerks.
For those of you that are familiar with our products, you know that we have been offering support for the n54/n55 platforms for a while now and our products are second to none in terms of performance, reliability, and fit & finish. So with that said, I would like to reintroduce our company back on E90post with our new Competition Series Dual Oil Coolers. This oil cooler upgrade kit was thoroughly designed and tested after 3 years of development under the harsh conditions of our competition/time attack 135i and completely solves the dreaded limp mode on our cars. The 135i/335i comes from the factory with a small oil cooler with a core size of 8.75"x4.75"x1" (222mmx121mmx26mm) which comes out to 41 cubic inches of core. The Competition Series Twin Oil Cooler system features two HUGE identical oil coolers 11"x8"x2" (280mmx203mmx51mm) with a core size of 9"x8"x2" (229mmx203mmx51mm) each. Each oil cooler comes out to 144 cubic inches which is 3.5 times larger than the factory unit each! Since there are two oil coolers, you have a combined 288 cubic inches of oil cooler core, over 700% more core than the factory oil cooler. Through 3 years of development and testing, our Competition Series Oil Cooler has kept our Time Attack 135i from seeing the dreaded limp mode issue due to oil temperatures. Regardless of conditions (ambient temperatures and track lay out), we have never exceeded 259F!!! This is in 110F+ track temperatures and wide open throttle pulls all the way to 6 gear (160+ mph). Through test cars used in our beta testing program, we are getting independently gathered, unbiased data showing the same exact thing. Each Competition Series Twin Oil Cooler mounts to its own box enclosure. Louvers on the backside of the box enclosure ensures airflow through the oil coolers while protecting the oil cooler from road debris, especially debris kicked up from the front tires. Also, traditional oil lines would typically be routed so that the oil gets split to each of the oil coolers (each oil cooler handling 50% of the oil) due to ease of building the system and lower costs. Our Competition Series Twin Oil Cooler System however are setup in a "sequential" configuration. What this means is that oil travels from one cooler to the other thereby 100% of the oil goes through both oil coolers. Our testing have shown significant increases in efficiency and performance running a "sequential" configuration. Our new CNC machined oil filter housing adapter (included in the kit) makes this possible. Key Features:
Here are the results of some independent testing done by our customers: Independent Test 1 (Buttonwillow Raceway) Independent Test 2 (Laguna Seca Raceway) Kit Options: When the oil cooler box enclosures are used in conjunction with our optional ducting shroud kits, the oil cooler box enclosure actually seals and forces all the airflow captured by the ducting shrouds through the oil cooler cores. Improves the oil cooler's effectiveness and efficiency. The ducting shroud kits are available in aluminum or carbon fiber. These are model and bumper specific so make sure you order the correct shroud kit. For additional information on our oil cooler kits as well as other products, please contact me or any of our authorized vendors on the forums and we would gladly answer any questions you may have! We also have a sport oil cooler for those that don't see extreme track duty. More info can be found here: http://www.evolutionracewerks.com/node/132 Last edited by Evolution Racewerks; 03-29-2012 at 10:21 PM.. |
11-08-2011, 07:28 PM | #3 |
74
Rep 1,543
How are nylon lines better than stainless steel? We've had more nylon lines brake and leak oil on this forum, than any other type of set up. Even the OEM rubber lines have never even once broken.
11-08-2011, 07:42 PM | #4 | |
140
Rep 863
The reason we use nylon lines is because Nylon lines are significantly higher quality than some of the cheaper nylon lines used on the market today. Our high end Goodrich Nylon Braided lines are the new thing to use for oil lines as they have many advantages and no disadvantages (other than higher price) than traditional stainless steel braided lines. The main advantage is that they are lightweight. Nylon is considerably lighter than stainless steel. The second advantage is that Nylon Braided Lines are stronger than traditional stainless steel lines. Third, is that Nylon Braided Lines do not fray. Stainless steel braided lines will start to fray and those who are familiar with stainless steel braided lines know what we're talking about. The stainless steel mesh in the lines start to "fray" or break and thus you get poked with the broken ends. Saves a lot of bloody fingers. Fourth, they are abrasive resistant. Since stainless steel lines will act like a saw when it comes in contact with anything and will eventually cut anything it contacts whereas the Nylon braided lines are soft and pretty much won't ever do it. Fifth, heat resistance. Nylon Braided lines can withstand more heat and retain the heat inside the line better. Stainless steel lines tends to release the heat inside the lines, thus when you touch the lines, they tend to be hot. With all these advantages of the Nylon Braided Lines over stainless steel lines, it's the obvious choice for an Evolution Racewerks product. Last edited by Evolution Racewerks; 11-08-2011 at 08:00 PM.. |
11-08-2011, 07:45 PM | #5 |
Team Zissou
3084
Rep 10,198
Maybe you mentioned it but I was busy looking at the pics - do you offer some kind of version that makes this work for us unlucky enough to not have the stock oil cooler?
11-08-2011, 07:56 PM | #6 |
140
Rep 863
Thank you for your interest, we do offer an all OEM parts retrofit for those that do not have the stock oil cooler. The kit includes oil cooler housing, thermostat housing, gaskets, and all hardware necessary for the install. Please pm me if you're interested as I am not allowed to post pricing unless it is in the sponsorship section.
11-08-2011, 08:09 PM | #7 |
11
Rep 160
I wonder if I got the AR oil cooler retrofitted(no OEM oil cooler), are your dual oil coolers compatiable with the parts I am using?
Also, price? |
11-08-2011, 09:22 PM | #9 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
Sweet! I saw this on your site the other day shopping around.. I carry a couple of your parts already on my 1 (FMIC, DV Charge Pipe) and this is def on my todo list.. I'm a fan of your products. You guys have quality stuff and top notch support. I haven't personally talked to you, but have had my conversations with Fred and he's an outstanding guy.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
11-08-2011, 09:34 PM | #10 | |
140
Rep 863
I'm actually new at ER, I've been a longtime forum member (my username is Jz). Feel free to contact me if you have any questions |
11-08-2011, 09:46 PM | #13 |
Rep 96
Im a evolution racewerks fanboy for sure i have the charge pipe, intercooler,injen intake(which I will admit was just for the extra tee shirt) and even the carbon engine cover so this is definitely on my list, can you update the web page with the price of the retro fit kit? Might be a while before I am ready for purchase. On another note when will ER be releasing your intake manifold??
11-08-2011, 10:49 PM | #15 |
915
Rep 3,456
Drives: Harrop E90 M3
Fred hooked me up with the sports oil cooler kit when it first came out. Pretty nice kit. Your lines are crazy light, that's for sure. Been running it a while with no issues. Free bump :-)
11-08-2011, 11:01 PM | #16 |
142
Rep 2,661
sick!
11-08-2011, 11:55 PM | #17 | |||
140
Rep 863
The intake manifold is coming... soon Quote:
11-09-2011, 02:09 AM | #18 |
86
Rep 1,993
Would this fit a RHD 335i with MTech body kit?
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
11-09-2011, 02:18 AM | #19 |
79
Rep 1,617
I have the sports version of this kit and it works great on my car!
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
11-09-2011, 02:21 AM | #20 |
140
Rep 863
We've never installed this on a RHD vehicle so I'm not 100% sure. I don't see why the layout of the engine and front bumper would be any different from a LHD though.
Thanks for your support, let me know if you ever want to upgrade! |
11-09-2011, 03:48 AM | #21 | |
263
Rep 2,563
I'm not a fan of braided lines at all, actually, be they nylon or steel braided. Just a short while ago I had a massive oil leak because one of the nylon lines I had from an aftermarket oil cooler rubbed through in the engine bay; this was because under the enormous oil pressure as well as heat they distend, and under load move around a bit, causing them to rub slightly on some sharp parts in the engine bay. In order to avoid that, IMO the only feasible alternative are steel flex lines (i.e. not braided ones). Of course that's a bit more expensive as they have to be custom made, but that's what I've put on my car right now in order to avoid any further oil leaks. And this is not a single occurrence, I know a few other people that had exactly the same problem. Aside from that, I think it's a great product. Still, another question: Due to the massive increase in oil volume, have you made calculations as to the capacity of the stock oil pump to deal with this? Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
