Has Anyone Touched 400 Whp Or More with a jb4 map 2 On 93 Oct Pump???
11-05-2011, 01:11 PM | #2 |
161
Rep 7,377
With no bolt ons? Impossible.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-05-2011, 01:20 PM | #4 |
68
Rep 1,943
Lmao
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-05-2011, 01:24 PM | #5 |
Joint Chiefs of Staff
4918
Rep 115,980
11-05-2011, 01:24 PM | #6 |
45
Rep 828
11-05-2011, 01:26 PM | #7 |
45
Rep 828
11-05-2011, 01:27 PM | #8 |
231
Rep 1,473
11-05-2011, 01:51 PM | #9 |
78
Rep 1,127
Op... use the search button
Dyno chart compilation. Just look what what people have in their mod lists http://www.e90post.com/forums/showthread.php?t=416797 JB4 + Helix intercooler + catless downpipes = 393whp http://www.e90post.com/forums/showpo...&postcount=154 JB4 + Full Bolt ons = 400 whp JB4 + Full Bolt ons + meth = 420 whp http://www.e90post.com/forums/showthread.php?t=473255 DCI JB4 93+ octane = 370whp http://www.e90post.com/forums/showthread.php?t=588574 Dynos to me are completely relative because of temps, elevation, how well the car is running, etc. Mine is like a bat out of hell and meets your title requirements with some extra bolt ons. Also you should not be running map 2 unless you have catless downpipes at a minimum.
11-05-2011, 01:54 PM | #10 | |
79
Rep 586
Muffler flap open=600hp easy
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
11-05-2011, 02:33 PM | #13 | |
45
Rep 828
I am running catless ,even the rear ones are deleted..I think the rear cats are good for 15 whp..I have yet to see a jb4 map 2 fbo with rear catless dyno..Yes the flap makes a difference opened,maybe not 600 whp..lol..Jeff I rememeber seeing a jb4 fbo map 2 on 335 make 405 whp ,it was posted on youtube some time ago. Last edited by thebigragu99; 11-05-2011 at 02:41 PM.. |
11-05-2011, 02:41 PM | #14 | |
51
Rep 923
11-05-2011, 02:50 PM | #15 | |
45
Rep 828
11-05-2011, 03:01 PM | #17 |
51
Rep 923
The exhaust isn't all that restrictive at lower boost levels. As you increase your boost higher it becomes more restrictive because there is more exhaust flowing. That is when you get the most benefit from a free flowing exhaust setup. Go ahead and do a dyno at stock boost and tell me how much power you gain from an exhaust. To say that the map doesn't matter is completely false because the map determine how much boost you are running. You will NOT gain 15 whp from removing the secondary cats especially at only 14.5 lbs of boost. The rear cats are not nearly as restrictive as the primary ones because of their location. The primary ones are so restrictive because they are almost immediately post turbo.
11-05-2011, 03:10 PM | #18 | |
45
Rep 828
11-05-2011, 03:26 PM | #20 | |
51
Rep 923
I'm not sure what you are seeking anymore. If you want to know what your car is putting out, then get it on the dyno. Be sure to do a run in bypass mode if you don't already have a baseline dyno run on the car. Without a baseline, the dyno isn't nearly as useful. |
11-05-2011, 03:33 PM | #21 | |
3441
Rep 79,211
11-05-2011, 03:33 PM | #22 | |
45
Rep 828
