Need N52B30 blueprints...
11-04-2011, 04:24 PM | #1 |
141
Rep 2,217
I'm looking at getting the first Oversquared stroker kit made for the N52B30 (3 liter) up to 3.2L. I need blueprints of the engine block and i can't find them via google... help?
I've chatted with a couple of camshaft producers and got in touch with Lunati in mississippi, they say they can probably give me an accurate quote, including research, production, and installation; depending on the need for new bearings, piston rings, etc. Ballpark price he said was looking at $7k if they matched the parts provided from Noelle, outputting anywhere from +50-100hp & 25-50ft.lbs tq. Noelle motorsports has an undersquared configuration (more torque increase vs horsepower) but it sells for $18k+ ... way too expensive. Last edited by N0OS3; 11-06-2011 at 12:59 AM.. |
11-04-2011, 06:33 PM | #4 |
253
Rep 7,089
Drives: '06 AW 330xi
I think VAC Motorsports did forged pistons and rocker arms for a N52B30. Maybe they would know.
Btw there was another company awhile ago that sold kits too. Not sure what happened to them. |
11-04-2011, 07:27 PM | #5 |
81
Rep 6,092
maybe im too old school "import"... but i never liked the idea of stroker kits. although the whole phrase of "no replacement for displacement" holds true for the most part, to me it's a matter of HOW that displacement is gained. increasing the stroke of a pre-built engine does increase displacement, which increases torque and shifts the curve down low to start early, but it kills the revs (in relation to the original engineered design of the engine). i'd rather increase displacement by boring out the cylinders (and reinforce the walls if necessary) to increase displacement, while keeping the stroke distance the same so that i can still maintain the original rev speed characteristics but at the same time still be gaining torque and horsepower from the new displacement. heck, if anything, with the block torn apart, and re-blueprinting all the internals, perfect time to swap out to all forged internals like stronger rods, more aggressive pistons, stiffer and stronger valvetrain, etc... this'll allow even higher revs, yet you still get the added benefit of plenty more torque from the increased displacement.
and then on the other hand... to dump A TON of money, which this will cost no matter what, is dumb imo. better to just get an e9x m3 or even an e46 m3. |
11-04-2011, 11:38 PM | #6 | |
141
Rep 2,217
The only company that did this that i know of is Noelle motorsports in europe somewhere and they charge way more than needed - i think what they do is make the product upon request instead of mass producing a product to sell at a cheaper price. They charge $18,000+ The tendancy i'm seeing though is that the block may only allow an increase up to +0.2L bore (up to 85mm). This supposedly allows for +50hp increase. The only play with creating a new crank shaft is to increase the stroke length, which is only increasing torque (they managed to stretch out a 93mm stroke) +100ft.lbs.tq in this case. I'd like to go 85mm bore at minimum for the 50hp, but more if it allowed. I'd maybe increase the stroke by a few mm above 85mm... maybe 86mm or 87mm stroke... assuming +70ft lbs tq. I'd think that increasing the displacement would create too much power on the crankshaft if i didn't increase stroke length so i'd have to get some torque to compensate. @gavin: i would take my car to mississippi (where Lutani is), but i don't think i could/would leave it there for months at a time for them to develop the kit... this i could totally see happening either winter next year or early spring 2013. |
11-05-2011, 02:41 AM | #7 | |||
81
Rep 6,092
dont get me wrong, im not trying to knock down ur ambitions. im all for ppl wanting to get more power from their cars; but im also a realist and just letting u know. best way to start off imo, is to take an engine and take it apart completely and put it back together and understand how/why that engine was built, designed and engineered it originally was first before u try to make ur own engine. if ur really serious about building an engine, u should really take the time to learn and understand basic engine dynamics; otherwise all this mod talk about stroker kits and "plans" to start not for another year is just talk. good luck and have fun. Last edited by edirtaynine; 11-05-2011 at 02:50 AM.. |
11-05-2011, 12:58 PM | #8 |
141
Rep 2,217
I NEED BLUEPRINTS
isn't that what forums are for... "talk"? Noelle is not charging $18k for a custom block... they're charging for just the parts, assuming you plan to bore your block yourself. I could see charging $18k for a full bored and stroked engine but that's not the case. Horsepower and torque is not calculations of each other, i learned these basics and where this comes from in highschool 8 years ago. Increasing bore size will ultimately increase horsepower due to increased volume for combustion. hotter fire = more pressure on the piston = more horsepower. Increasing stroke (lengthening the amount of travel the piston makes when pressed) increases leverage on the crankshaft. more leverage = more torque. It's like cranking a hand wheel. The length of the crank attached to the handle provides leverage, requiring less effort from you to turn it. The force/pressure you put into turning that handle is the horsepower. Overall, if leverage and force is used to turn this crank; whatever you're turning is moved by the torque provided. Even bore size and stroke (lets say 85mm bore and 85mm stroke) is an even[squared] setup... you will have equal horsepower with torque. Truck engines are designed with a high stroke rate to provide a big torque curve for hauling trailers, heavy items, etc, NASCARs on the other hand are higher bore vs stroke... they keep high speed for long distances so no need for all the torque slowing you down. ^^ this is not trying to insult your intelligence, this is for other less knowledgeable viewers that stop by this topic. So... back to my ambitions, it may or may not happen... it would be nice but i'll have to see if i'll be getting a supercharger or this stroker kit first. I can see both projects costing me nearly $10k. My projects were in the works for an S85 swap not too long ago. I still have the 7DCT, but i managed to sell the V10 last month... cost me $10k from ebay shipped and i had to sell it off for $8k... |
11-05-2011, 07:02 PM | #9 |
194
Rep 933
Check your PMs ;-)
Brian Casella
Sales Representative, VAC Motorsports Office: 215.462.4666 | Fax: 215.462.4667 EXT 13 | Email: brian@vacmotorsports.com |
11-06-2011, 12:09 AM | #10 |
Rep 164
Mike can you please send me the information as well. I started a thread like this at one point and I was at a standstill on creating pistons, rods, and drivetrain options because I didn't know the specifics. I would be very very interested in something like this. I would not stroke mine though. I would just want to up the CR and get a high revving beast of a motor.
Lync from everything I have researched Horsepower and Torque are directly related to one another. Horsepower is defined as work done over time. That's why than Honda's and Rotary motors have good horsepower. I mean the 13b in the RX-7 and the Renesis in the RX-8 can revv to 13k rpms. Its not even that its causing damage by revving to quickly. The harmonics of the engine are exceeding what can be cancelled out by the damper and it destroys the engine above that rpm. Horsepower is literally figured out as an equation in motors. Its actually a simple one. HP=TQ X RPM / 5250. The way to get horsepower is to get a high revving motor. The way to get gobs of torque is be a damn diesel with an 18:1 CR and don't revv past 3k lol. |
11-06-2011, 12:31 AM | #11 |
88
Rep 1,105
I would hesitate doing such a mod for that amount of money. I believe the stroker kits are largely overrated in terms of increase in HP. If you look at the dinan strokers for the m3 and m5, there are many posts and videos of guys very unhappy with very little power gained compared to what is promised. Even the stroker on the m5 which gains from 5l to 5.6 I believe has true gains of less than 50hp. Therefore from 3 to 3.2 in this engine absolutely will not yield 50. Likely if you do everything perfectly you may see a true solid 20-25 hp gain which is nice but just not worth it in my opinion. Google around and read a bunch of stories from disapointments in dinan's stroker kits
11-06-2011, 01:02 AM | #12 |
141
Rep 2,217
i updated the OP with the link to Noelle motorsports Stroker Kit package... they say they can pull quite a bit of torque and hp out of a boost from 3.0L to 3.2L....
11-06-2011, 01:46 AM | #13 |
141
Rep 1,108
lync,
why didnt you go through with the v8 transplant? man, you spent $10k on the v8, meaning you were prepared to spend few more grands for the labor & whatnot for the transplant. I would trade-in the car with that money.
My e90
Frozen Grey. Dry CF Roof. Vorsteiner Double Sided CF Boot Lid. OSS. BMW Performance Aero Kit. BMW Performance CF Diffuser Cover. BMW Performance CF Trim. Robson Design Steering Wheel. Advan RS. Michelin PSS. H&R Touring Cup Kit. BMW Performance Brakes. Eisenmann Race Rear Muffler. ESS Directflash |
11-06-2011, 03:08 AM | #14 |
Rep 164
I wish that Winter tuning also had a shop over here to tune the car as well. They have a great tune for the car. Lol of course they are in Germany.
Lync did you get your blueprints from VAC? I would love to see them if you did get them. |
11-06-2011, 11:12 AM | #15 |
Freight Dawg
104
Rep 2,103
Well when my engine goes you'll have yourself a car.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
11-06-2011, 12:45 PM | #16 | ||
141
Rep 2,217
-sorry for the long explanation Quote:
Mike@VAC said he will get back to me and see if they still have the blueprints for the kit still in the system... -i'm assuming that if they do still have the parts in the system, it would cost me much less in labor and essentially be paying for materials and labor costs in generally making the parts themselves (vs. paying for time spent designing the kit) |
11-06-2011, 12:57 PM | #17 |
88
Rep 1,105
So you paid almost 20k for a v10 and a dct tranny to stuff into a stock 325? You really think your chassis could take 500 hp? Not to mention suspension, wheels, brakes. Probably atleast another 20k to change that.
In the most polite way, what were you thinking? |
11-06-2011, 01:09 PM | #18 |
Freight Dawg
104
Rep 2,103
I'd be really interested to see how the DCT mates to the N52. This engine would really benefit for the extra gears.
--Marcelo
11-06-2011, 04:24 PM | #19 | ||
141
Rep 2,217
I bought the 7 speed transmission later for another $7,500 i had on hand already (from my nest egg). Also to add, my theory is that since i paid $26k for my car... even if i put an upwards $30k into the engine to get it up to 420hp or more, i'd have matched or outsourced the power of an M3 for less than the price of one... again, just a theory. Eventually, if this car is maxed out on the potential modification it'll just be my track car and i'll be driving something more fuel efficient. As for the 'can the chassis handle it'... absolutely. Of course, this is assuming that I upgrade the suspension as well... a hard/rough setting on the coilovers, dampers, shocks, will play a large roll in keeping the drive-ability there without gutting the car to install a roll cage. Suspension isn't a problem price wise... $2000k for a top notch brand or $2500 for electronic coilovers. Brakes can still handle the weight of the car no problem... if i put some performance rotors on, i think temporarily i'll have met performance demands by simply having cooler (drilled/slotted rotors) brakes. **Hartge did this project a long time ago, but they have corporate funding and have access to any part they want on short notice. They typically sell theirs for upwards of $180k or more, but they not only put their stamp on the whole car, but its warranted to function with all normal standards of your average 325i/M5. Quote:
I considered trading my 7DCT for a 6-speed manual from a 335, but it would benefit a lot from having 7 gears (acceleration and fuel efficiency). I may also be in the market for the upcoming 8DCT from BMW's new hybrids, but again; i don't think they'll handle 300hp-500hp |
11-06-2011, 06:21 PM | #20 |
Freight Dawg
104
Rep 2,103
Getrag made the 6mts in the 325. If their past work is any indication of what this gearbox is capable of then here's some food for though: the Getrag 226 (e39 M5/540, e46 M3, and more) could handle 1000hp and 800ft-lbs of torque. Several people had supercharged M5s with similar power with stock gearboxes. The M5 had just shy of 400 HP stock. The 226 had one weakness though. The syncros were weak and could not be shifted fast constantly or when cold without really wearing it out.
--Marcelo
11-06-2011, 07:00 PM | #21 | ||||||||
just another bmw douche bag
195
Rep 3,640
same thoughts from me. Just make sure you know what you are getting into before you start. There is nothing worse than starting a project you can't finish. |
11-06-2011, 11:31 PM | #22 |
141
Rep 1,108
dammit Lync,
You're nut, man! :-) Building and/or transplanting a motor is like the ultimate orgy, it costs a lot money & efforts, but it's damn satisfying i'm sure, figuratively speaking :-) However, you were gonna build the car to track it, then with all that money, I'd just gut the 325i, get some light wheels, suspension, rotors & pads, & I'll have a hell of a car for the track needs & still have enough $ for a beater for DD. It's more cost effective in maintenance for sure. With $8k in hand, I'd keep the 325i the way it is for a DD, then get a track-ready spec miata & track the hell out of it.
My e90
