COBB AP Traps 126+ and 7.59sec 60-130mph, 6.53sec 100-200kp
11-02-2011, 04:59 PM | #1 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Please note that the 60-130 gas been improved to 7.59 and 100-200 to 6.53. See later posts.
Quarter Mile: Dzenno's slips below. Full weight MT 335i FBO/RB turbos with cobb alpha maps. WOTBox - No lift shift configured with 100ms coil delay 94 pump plus 100% meth. jb4 was not used for boost control. The boost was fully controlled by ecu. Meth is boost activated at 8psi min 12psi max flow 100% meth by using the coolingmist vc-2 progressive controller Please note that this information is to the best of my knowledge accruate and I will update as I learn more. Last edited by mithiral67; 11-05-2011 at 03:05 PM.. |
11-02-2011, 05:16 PM | #3 |
68
Rep 1,943
That's fast! Congrats
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-02-2011, 05:20 PM | #4 |
112
Rep 4,771
Dzenno did a 126.6 on COBB. LM did a 127 on JB4. Now all we need is syndicategt to do a run with his RB's and Procede in the 126-128 region.
Seems to me that the RB's perform very predictably. Which is a good thing. |
11-02-2011, 05:21 PM | #6 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Was this on a custom map?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
11-02-2011, 05:24 PM | #7 |
That guy
117
Rep 5,740
The RBs hitting 18psi at redline is a huge advantage over stock turbos.
11-02-2011, 05:24 PM | #8 |
That guy
117
Rep 5,740
11-02-2011, 05:32 PM | #9 |
That guy
117
Rep 5,740
Dzenno - Cobb AP - 7.79sec 60-130mph, 6.73sec 100-200kph
Removed as he improvded his times, see rests of thread.
11-02-2011, 05:50 PM | #12 |
153
Rep 3,730
Working on it however, if I do, my Sac times will be discarded by most (guess I need to get a Vbox).
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
11-02-2011, 05:50 PM | #13 |
112
Rep 4,771
He's not doing that anymore apparently. But with the stage 2 maps he would have it configured so that the JB4 added boost when meth was flowing or something along those lines.
And this isn't a custom map, but an alpha map of COBB's upgraded turbo map. |
11-02-2011, 05:59 PM | #14 | |
68
Rep 1,943
11-02-2011, 06:13 PM | #15 |
153
Rep 3,730
My only update was I went to the track 2 weeks ago and had HPFP issues, so I didn't get any good runs in (I still managed to hit a 13.1 by letting off the throttle at the 1/8 mile and braking before the 1/4 marker with my 1/2 engine light). My LSD is broken in, so I can start beating on her harder now. Hitting up Infineon and Laguna Seca in the next 2 months as well. Other than that, I been extremely busy with work and havn't had time to do much with my car.
11-02-2011, 06:28 PM | #16 |
38
Rep 565
Title should read RB traps. Boost is boost.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
11-02-2011, 06:31 PM | #17 |
812
Rep 3,974
1.77-1.85 60' times are pretty decent. I only wish I had a 1.77 sec 60' last weekend!
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
11-02-2011, 06:35 PM | #18 | |
51
Rep 923
Answer:
11-02-2011, 06:40 PM | #20 |
153
Rep 3,730
But not all tunes have the same boost taper, AFR's, power curve, ect....
11-02-2011, 06:42 PM | #21 |
That guy
117
Rep 5,740
ugh, thats my bad, was cleaning up the posts and trying to make them appear similar. From my understanding, the 1/4 mile was at full weight and the 60-130 was reduced weight. I believe wheels were different as well, but they werent materially different then normal.
