Burning Oil after Jb4 - Need Help
11-02-2011, 07:34 AM | #2 |
161
Rep 7,377
You installed jb4 on top of dinan?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-02-2011, 07:37 AM | #3 |
BMW Enthusiast
73
Rep 154
Yes, is a piggyback tune which basically over-rides the Dinan tune to just have the Jb4. But upon removing Jb4 still have dinan.
2020 BMW X3 M40i, Black Saphire Metallic, Evolution Raceworks High Flow Catted Downpipe, BootMod3 Custom Tune, Bavsound, Ceramic Coated
11-02-2011, 07:39 AM | #4 | |
161
Rep 7,377
You cannot just stack jb4 on top of a flash. You can run some kind of custom map but i dont think is a very good idea running map 2 on top of Dinan with Dps only .
11-02-2011, 08:06 AM | #5 |
97
Rep 2,002
I don't think it "overrides" the Dinan at all. If I put a piggy on top of my giac it would def. Cause problems unless I used the map that bms designed to have stacked on a flash. The jb4 has a special map that can be used when stacking it on top of a flash but if you u aren't using that map then I wouldn't have it installed. You should talk to bms to ask them which map to run when you stack it on top of a Dinan.
ESS 650 ACM-R Upgrades |
11-02-2011, 08:19 AM | #6 |
812
Rep 3,974
Something is definitely unusual in your case. I have been boosting way higher than your map #2 would normally, hundreds of qtr mile runs, etc. No blue smoke or excessive oil consumption ever. Definitely check with BMS on the compatibility of the flash and JB4. I mean I was accidentally running 20psi on map #6, since I didn't know the meth additive applied to that map, and still no problems, so perhaps your car was on the verge of failure to begin with, and the higher boost finally caused something to fail.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
11-02-2011, 09:07 AM | #7 | |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
Enrita is right, you cannot assume you can stack the JB4 on top of the Dinan flash software. If I were you I would have the Dinan software removed and run just the JB4 if you are looking for more power OR upgrade to a higher stage of Dinan software/mods.
I've never heard of any tune causing irregular oil consumption. Remember, these N54 motors push/burn/evaporate oil unlike most factory motors.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
11-02-2011, 09:37 AM | #8 |
台灣 台北市
88
Rep 1,267
Drives: 2009 GT-R Premium
my friend's 07 n54 has alomost the same problem too. but he has jb4 only. he got oil burning, alot of white smoke comes from exhaust, boost leak(max is only 7psi), half engine light on, misfire...etc. issues. now he doesn't know how to do either
has scheduled to go to shop next Monday
11-02-2011, 10:03 AM | #9 |
BMW Enthusiast
73
Rep 154
BMS said was Ok to stack tune and didn't mention running custom map
11-02-2011, 10:17 AM | #10 | |
246
Rep 3,441
I know they have stacked the JB+ (plus) on top of the GAIC and the Dinan to bring up the boost 2lbs, but JB+ is a much different (simplier)tune than the JB4. I have not seen them stack the JB4 with a flash tune. Not saying it hasn't happened.
11-02-2011, 11:02 AM | #11 | |
Joint Chiefs of Staff
4918
Rep 115,980
Make sure you set the fuel settings all To zero When using jb4 with a flash. Maybe it's just way too rich. A log would help. Mike Last edited by Mike@N54Tuning.com; 11-02-2011 at 12:05 PM.. |
11-02-2011, 12:22 PM | #12 |
BMW Enthusiast
73
Rep 154
Mike,
So when logged in with my laptop under settings put the fuel pressure mapping setting to zero? Or do I use another setting?
11-02-2011, 12:47 PM | #13 |
45
Rep 828
11-02-2011, 01:17 PM | #14 | |
Rep 338
I am also running JB4 with their meth kit stacked on top of Dinan Stage 2 (also have CAI, FMIC, and AR catted DPs). On another forum, Terry mentioned that the stack, while ok, was not "ideal". Asked for further explanation, but never got one. Reason I asked is because I am more than willing to remove the Dinan flash if it will make my setup "safer". So, couple things: 1. Can you comment on why the stack is not "ideal"? 2. Would you recommend removal of the Dinan flash? 3. Might be helpful if BMS had a sticky with any specifics about stacking. For example, I did not realize that "all fuels settings should be set to zero" like you state above. Thanks for all the help you and Terry have provided. Always very quick in responding to emails, etc. Great customer support overall. |
11-02-2011, 01:21 PM | #15 |
Rep 227
07' E92 with downpipes, DCI, Catless Exhaust and Dinan Stage 1 with 64k miles. Have enjoyed the car and recently wanted more power and installed the Jb4.
11-02-2011, 06:51 PM | #16 | |
4918
Rep 115,980
Mike |
11-02-2011, 09:55 PM | #17 |
Rep 338
11-03-2011, 12:42 AM | #18 |
102
Rep 2,760
You guys don't know how much beating your cars took in previous life, so who knows if that is affecting what it can handle? I would be careful pushing it. Extra juice means nothing if your engine is already weakened to the point it wont handle any extra when you consider you might windup breaking it.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
