Procede settings
11-02-2011, 12:11 AM | #1 |
Rep 106
Procede settings
I have a Procede v4 I bought off the forum and installed with the default settings. I recently went to the track stock + procode and was able to run a 13.2 at 108 with map 1 settings which I believe is set for 13.5 psi. I am getting ready to install AA pipes, ETS intercooler and a DCI so I was looking for suggested settings since I should be able to run more boost. I want to get it set up so once I have the car apart I can hook it up and not have to go back in after the install since getting to the ECU takes a bit of time. What settings are you guys running on the Procede with FBO? Any suggestions would be greatly appreciated.
11-02-2011, 01:38 AM | #2 |
40
Rep 957
with FBO run on map 2. can set your max boost to 18, start boost to 50%, IC to 50%. that is assuming you have autotune off.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
11-02-2011, 01:49 AM | #3 | |
161
Rep 7,377
There is not much you need to change with autotune on . Run first the stock settings on map 2.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-02-2011, 11:05 AM | #6 |
11
Rep 124
I'm in the same situation as the OP.. I just recently installed catless DP's and exhaust but am currently running the Procede V4, I haven't changed the settings at all, just installed and let it autotune.
I'm a total newb when it comes to adjusting the settings and what not, and was also thinking of updating to the V5 software, any advice on this and any changes I would see?
335i Coupe|BSM/Red Coral|BBS LM-R DBK|H&R Coilovers|OEM M3 Lip Spoiler|Many more pending..
11-02-2011, 11:47 AM | #7 |
Rep 106
I will not be running meth so that is not an issue. What about this autotuning feature? The one earlier posts recommends 18 psi with no autotune and you are suggesting 16 with autotune. I have it on default which is "on" if I am not mistaken but if it beneficial to turn it off I would definitely do so.
11-04-2011, 07:36 AM | #10 |
103
Rep 3,177
i would suggest downloading the 7-29 maps, firmware, and v5 computer interface software. upload the firmware and maps per the directions in the readme file. then, enable autotuning on either map 1 or 2 (or both). don't mess with any other settings, unless you have wastegate rattle. then, just drive, autotuning will do the rest.
if you need help, i live in katy, pm me and we can meet up somewhere if you need. |
