Bit by the misfire bug!
11-01-2011, 03:16 PM | #1 |
55
Rep 1,690
I have been reading a lot of posts about misfires lately and was just waiting for it to happen to me. Last night driving home and I went to accelerate pretty hard and the service engine light came on and the car started to shutter. Everytime I would touch the gas the car would vibrate like it was rattle itself part. I pulled over turned the car off for a bit and started it back up and it drove just fine. When i got home I scanned it and I had misfires on cylinders 3 and the obvious cyclinder 5. My car has 52k+ miles and I'm runnng the JB+ at about 75%.
I orderd all the parts today, plugs, coil packs, and a spark plug tool, but they won't be here until hopefully the end of the week (maybe not till next week). I am going to drive it a miminal as possible, but is it ok to drive it until I change out the parts? Obviously I am going to drive it like a granny, but as long as I don't push it hard is it ok to drive? |
11-01-2011, 03:20 PM | #2 | |
103
Rep 3,177
11-01-2011, 03:25 PM | #3 |
55
Rep 1,690
Thought about that right after I created the post. Just pulled it out. I really appreciate the advise.
11-01-2011, 03:38 PM | #4 | |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
11-01-2011, 04:07 PM | #5 |
133
Rep 4,764
Sounds like a plan. Try plugs first and see if that fixes it. I just have rough starts at this point, for the first 45 seconds after startup (no misfire codes yet). My car will be 5 years old in March. Will try new plugs in the spring and then new coils if the rough starts don't go away. Hoping the injectors hold up a few more years.
11-01-2011, 08:04 PM | #6 | |
55
Rep 1,690
Thanks again guys for the help/advise! |
11-01-2011, 08:30 PM | #7 |
DJ Hess
Rep 25
Keep us informed. I too have had the same prob. Removed the COBB and runs fine. I am going to order a couple plugs. Current plugs have around 5k miles on them and also had injectors done around the same time. I might order a coil pack also, just to have around. Will get them from Tischer...BMW San Antonio wants twice as much!!!
11-01-2011, 09:41 PM | #8 |
246
Rep 3,441
Good luck solving the problem....and definitely report back.....information is key when owning an N54
11-04-2011, 01:22 PM | #10 |
102
Rep 1,903
Drives: e92 335i 6MT
Do coils need be replaced as a set (of 6 or 3), similar to plugs? Or is it okay to only change the one that is causing misfire?
11-04-2011, 02:13 PM | #11 |
130
Rep 2,291
11-07-2011, 01:33 PM | #12 |
377
Rep 2,982
What was the issue?
This morning my 335is died on me finally at just under 19k miles. Had rough idle that went away after about a quarter mile driving the past week and a half. This morning it was beyond bad and got the SES light and a lot of white smoke coming out. Likely a lot of unburnt fuel because it smelled like trashy cigarette boats on Lake Havasu. When I'd try to drive, it sputtered continually and the white smoke wouldn't stop. When idling the RPM bounced up and down from as low as 400 rpm and 1400 rpm. Had it towed to Beverly Hills BMW so we'll see what they say. Hopefully I get the car back today because I had to steal my gf's car for the day. This dealership has a 2 week long waiting list for loaner cars and charges for enterprise cars if you didn't buy the car there. No thanks. |
11-07-2011, 02:06 PM | #13 | |
125
Rep 2,172
11-07-2011, 03:44 PM | #14 |
377
Rep 2,982
How long did it take BMW to fix this? It was definitely a bad unburnt fuel smell with a lot of white smoke. The puff of white smoke came out in very rapid but defined puffs (likely from each exhaust stroke of the bad cylinder). Happened a ton when cold and only when cold. This morning was the first where it did not subside.
11-07-2011, 05:24 PM | #15 | |
125
Rep 2,172
11-08-2011, 10:36 AM | #16 |
55
Rep 1,690
Update
Changed my plugs this weekend and overall the plugs didn't look that bad when i pulled them out minus cyclinders 3 and 5. Install took about an hour and wasn't that bad. Just a helpful hint but when I received the new plugs it's obvious two of them were damaged during shipping. So I had to regap them. But just double check I rechecked all the gaps and almost all of them needed some minor adjustment. http://www.e90post.com/forums/showthread.php?t=604559 Last edited by BoostedE90; 11-08-2011 at 10:42 AM.. |
11-08-2011, 05:01 PM | #17 | |
377
Rep 2,982
SA said they replaced the hpfp first and foremost, then noted that there were a lot of other codes thrown, including injectors, maybe coil packs etc. I'm not sure what else, but I'll see the list of damage later on today. I just want my car back lol. I've been driving my gf's C300 the past two days because this dealer won't give me a loaner or rental for free. |
11-08-2011, 05:31 PM | #18 |
377
Rep 2,982
Damage done was 1 hpfp, 6 fuel injectors, 1 ignition coil. Not bad lol. I don't know what caused what to fail. Does the hpfp cause the rest of this stuff to fail?
11-08-2011, 07:49 PM | #19 | |
125
Rep 2,172
I can't believe the dealer wouldn't provide you a loaner. The only time I wasn't able to get a loaner was at short notice like same day and the dealer was really swamped... |
11-09-2011, 01:04 PM | #20 |
377
Rep 2,982
^right? about the loaner car. This dealership is a pretty high profile one that I always avoided because of cheeseball business tactics like that. I automatically dislike service centers that don't give you a free loaner or at least a paid pos rental car. Buy a 2011 BMW, get stranded. I shouldn't be left with a shuttle that will only take me halfway to my office.
There are other dealerships I go to for planned service because they have a loaner for me regardless of where I purchased my car, as well as free oil top offs etc. It's just going the extra mile to get customers to frequent your business. |
11-09-2011, 11:54 PM | #21 | |
54
Rep 740
Thanks |
11-10-2011, 10:27 AM | #22 |
55
Rep 1,690
Yes they did! Car idles great and no misfires. I still have a bit of hestitation when I step on it but I think that might fuel related.
