Dyno Results - FBO + Rev3v5 + PWM ... Map 0, 1, 4 comparison
11-01-2011, 12:29 AM | #1 |
30
Rep 314
Drives: 07 BMW 335i Sedan+2 Baby Seats
Hi Folks,
Long time no post/chat ... 3rd kid and a new startup doesn't leave time for anything else. Here's my mod list: - see signature ... new changes listed below - PWM meth kit (75/25 mix) - Procede v3 running the latest firmware and aggressive maps - 91 octane with a splash of 95 ... Probably around 93 octane The dyno was at the Mustang Ranch in Santa Clara, CA. It was a 2WD dynojet that was lifted off the ground and they had a very impressive cooling fan for the intercooler and radiator. They use a tailpipe mounted AFR sensor. The Goal: - see how much power each of the maps generated (map 0,1 and 4) - see if there were any issues map switching quickly between runs Some Conclusions: - I am making more power and torque than before using less boost and lower octane (this was with old meth kit and Rev2) ... I need to dig up the old dyno plots, but I was peaking at 420-ish whp with 430-ish torque on 110 leaded, 20 psi and 100% meth - map 0 seemed to be richer AFR (by about a point) than my stock tune - mapswitching between runs didn't make the AFR go wonky or anything strange ... It seemed very steady. - Very consistent run to run performance regardless of running back to back or giving it a minute for cool down (but i saw this before) - Map0/stock(with FBO) 299whp - Map1 (93oct): 391-395whp - Map4 (93oct+meth): 430-433whp Thanks for reading ... Junk
11.535@124.423mph (1.641 60') - AutoTune 7-27, Race+Meth, Best ET w/ only 80% throttle 1st and 2nd
11.647@121.356mph (1.590 60') - AutoTune (beta pre-5-15), Race Gas, No METH Perf Mods: Vishnu PROcede Rev3 v5, Vishnu PWM Meth Kit, AR Design DPs, AE Exhaust, Helix FMIC, Vishnu DCI, Forge DV, WaveTrac LSD (Best Trap - 124.665mph) |
11-01-2011, 01:04 AM | #2 |
112
Rep 4,771
I'm surprised you're gaining so much between map 0 and map 1 and "only" 40 hp or so between map 1 and 4. Seems to me that you are taking full advantage of your mods and running the optimal boost on map 1, but that you might be able to push it a little more with meth. What boost are you hitting with each map?
11-01-2011, 01:17 AM | #5 |
30
Rep 314
Brey335i - I don't have the logs on me ... i'll check them out tomorrow, but i think i was peaking out at 17psi and then tapering down to 11-12psi at the top. Its the aggressive map ... completely unmodified.
Jeff - the baseline dyne is with FBO and Map 0. So not 100% baseline (i.e. stock with no mods) Junk
11-01-2011, 01:57 AM | #7 |
29
Rep 968
Drives: 2007 335i Coupe
Great numbers Junkie!!!!! This is the second dyno thread runing this type of set up with great numbers and a baseline dyno. Keep running strong and consistent!!!!
http://www.e90post.com/forums/showthread.php?t=603517 |
11-01-2011, 02:17 AM | #8 |
30
Rep 314
SIKH335 - I just noticed your post too ... I thought we were close in car output, but now I notice I'm considerably down on power (your numbers had HFC and mine is completely catless). You need to lose those things and run your car at the track.
Junk
11-01-2011, 07:11 AM | #10 | |
55
Rep 944
11-01-2011, 10:21 AM | #11 |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
Very impressive results yet again for FBO+PWM meth. Must feel great seeing those numbers on your car.
11-01-2011, 10:25 AM | #12 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
That's what I'm seeing on my P3 boost gauge.
11-01-2011, 10:31 AM | #13 |
Made in Italy
31
Rep 287
Drives: Former 135i
11-01-2011, 12:47 PM | #14 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Nice results Junkie . I'll go through all your logs and post the relevant ones up later today. I assume that they match up numerically with your dyno run files?
Also, your map0 runs are now identical to the stock tune runs. Unlike older Procede maps, the newest aggressive maps/fw don't effect AFR targets in Map0. |
11-01-2011, 12:54 PM | #15 |
133
Rep 4,764
When are the maps getting a general release? Will the aggressive maps work with the PPS meth kit?
Nice numbers! |
11-01-2011, 01:19 PM | #16 | |
3441
Rep 79,211
They will work on PPS. It will be out when it comes out (IDK) |
11-01-2011, 01:24 PM | #17 | |
29
Rep 968
Let me know the next time you hit the track I will come out. I'm just working some suspension bugs out but should be ready soon. I was catless but didn't like the smell. These cars feel great congrats again for solid numbers. Sikh |
11-01-2011, 01:41 PM | #18 |
1737
Rep 17,960
Drives: A Lot
Datalogs
Map1 Map4 |
11-01-2011, 01:44 PM | #19 | |
1737
Rep 17,960
Drives: A Lot
The new aggressive maps will work with a PPS meth, just not as well/consistently based upon the logs that I've accumulated over the beta testing period. |
11-01-2011, 01:53 PM | #20 | |
133
Rep 4,764
11-01-2011, 02:00 PM | #21 |
Made in Italy
31
Rep 287
Drives: Former 135i
11-01-2011, 03:22 PM | #22 | |
1737
Rep 17,960
Drives: A Lot
shiv |
