A question on a new future on Procede 5.3 User software
10-31-2011, 10:57 PM | #1 |
Rep 75
Hello
Just wondering if anyone noticed that on the new Procede v.5.3 software, under the user map adjustable, there is a new future "OL Fueling", anyone know what this the function of this new future? Thanks |
11-01-2011, 10:05 AM | #2 |
14
Rep 284
Its a global offset for the Open Loop Fueling tables.
PROCEDE V5, AR CATLESS DP's, HELIX FMIC, ER CHARGE PIPE AND TIAL BOV, OHLINS ROAD AND TRACK COILOVERS, INJEN INTAKE, AWD TURBO UPGRADE, VISHNU PWM METHANOL INJECTION, AMS CATBACK EXHAUST, M3 FRONT SUSPENSION COMPONENTS,VOLK RE30 19X9F 19X10R W/ YOKOHAMA ADVAN AD08 265/275
11-02-2011, 02:23 AM | #4 |
68
Rep 1,943
No leave it alone unless shiv tells u otherwise. Email him some log he should be able to tell u.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-02-2011, 06:58 AM | #5 |
29
Rep 1,551
If your fuel trims are high (positive or negative), you can adjust it on a per map basis accordingly. I tried to keep mine <10%. Normally I saw fuel trims swing most at the onset of WOT and settle by a few points after.
Adjusting OL Fueling scaler to a medium would be easier than modifying individual cells in the OL Fueling map. I used 5.2 at the time though and this option was grayed out. |
11-02-2011, 07:27 AM | #6 | |
161
Rep 7,377
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-02-2011, 08:12 AM | #8 |
161
Rep 7,377
11-02-2011, 08:20 AM | #10 |
161
Rep 7,377
no here is serious business i just wanted to know from your experience how much you would lower if they are maxed out
11-02-2011, 08:35 AM | #11 |
29
Rep 1,551
In my case, I was seeing swings in trims initially from 23-28, and settling around 17-23ish. For a car with stock twins, this isnt terrible, but if I can adjust it, why the hell not. I only experimented with scaler offsets between 5-15% with decent success. Wasn't too concerned at the time as the logs reported mid 12's AFR.
In the OP's case, I don't think many people have to worry about the OL scaler. |
11-02-2011, 04:14 PM | #12 | |
Rep 75
Let me try to rephrase to see if I get what you are trying to say. So by datalog the fuel trim channel, if there is a + or - swim on fuel trim say on map1, I would then adjust the value + or - of OL fuel trim accordingly? However, if the current AFR seems to be within 13 or below then there is no need to make adjustment on OL fueling scaler? |
11-02-2011, 04:20 PM | #13 |
68
Rep 1,943
At 1 point I went down to 30% and still seen negative numb on the fuel trim up on top close to redline. So I call shiv he suggested I change my precede so he send me a new rev2.5 and it's working perfectly now.
11-02-2011, 04:47 PM | #14 |
Rep 75
Thanks for sharing ttbmer, so what I need to do now is Log!
11-02-2011, 04:51 PM | #15 | |
68
Rep 1,943
11-02-2011, 05:06 PM | #17 |
65
Rep 1,708
Actually I've changed my table pretty drastically and have seen improvements, but I think either my hardware or potentially BMW software is different then most. If anyone is MT and running latest maps I'd love to view some logs as comparison. PM me.
Some notes on mapping fuel: - OL global adjustment is a %, so basically multiple by table value for actual OL modifier - Fuel correction is the OL value being applied. I believe this is a subtraction to the rail pressure voltage which makes the DME add pressure. - Fuel pressure is related to fuel correction. I am curious what the actual relationships are: voltage = fuel cor and voltage = pressure. According to Shiv you want to see positive trims so you are always adding fuel. I noticed very poor performance with overly negative trims. And this can be noticable in your AFRs with either fluctuations or too rich/lean then the target. I think there does need to be a little refinement to the AFR table potentially since everyone (at least the logs I've seen) seems to be slightly rich... in my opinion at least. I haven't touched these yet. |
11-03-2011, 07:47 AM | #18 | ||
29
Rep 1,551
bmw_fanatic, if youre unsure, send your logs to vishnu. No reason why they shouldnt be able to check it out and give you a reccomendation. Though for most of the cars on here, you wont need to touch the OL fueling map. |
11-03-2011, 11:15 AM | #19 |
184
Rep 2,841
With the latest maps I think Shiv has increased OL fuelling quite a bit in order hit the AF target sooner after WOT onset.
It does the trick based on many of the recent logs we are seeing posted. But he did go on record stating that he feels the engine runs best with slightly elevated fuel trims and less OL fuel adjustments. That parallels my experience. The less OL fuel adjustment I apply......the fuel trim graphs become much smoother and have fewer spikes and oscillations. So there is more stability in the fueling process. I think this means the DME is happier overall as I experience significantly more post-shift timing flatlining when a lot of OL fueling is used. The downside is you run a little leaner a bit longer at WOT onset. |
11-03-2011, 11:41 AM | #20 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
