Cyba air intake scoops installed..
10-29-2011, 06:43 PM | #1 |
125
Rep 1,546
Got my cyba scoops today to aid in bringing some air to the DCI..
For the price the fitment was dead on and the design was pretty good. Slits at the back of the scoops are nice so no rain goes up into the intake track. Fit is perfect, and one bolt and a plastic clip hold them on pretty damn well. Only one problem i had was one small piece which came up to high and up in the front, did not let the grills install flush and correctly, so i cut off that small tab to allow enough room for the grills to install correctly. I have them marked off in red in the picture below. ALSO, i made my own hanger type bracket out of alum. and painted it in black, to use the stock snorkel to hold and keep it poiting directly at the DCI. Works well and really brings the air right into the DCI. The snorkel without this bracket, sends air the intake manifold and down. This bracket helps lift up the snorkel and point it direct at the DCI. This and the DCI work amazing to bring cool ambient air to the DCI. Last edited by Bagelfast; 10-30-2011 at 09:20 PM.. |
10-30-2011, 10:43 AM | #5 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
did you notice any power gains?
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
10-30-2011, 06:46 PM | #7 |
125
Rep 1,546
All i know is, the DCI themselves are alot cooler after im done driving when i touch them... They use to be damn HOT when i was done driving.. i think scoops help alot! Brings alot more air and alot more cooler/ambient air to the DCI. Throttle response on the highway seems def great.
10-30-2011, 08:50 PM | #9 |
125
Rep 1,546
You can see the scoops have slits at the back end of them where the rain/water would escape out of the intake track.
Honestly there is no way, even if the rain somehow escaped the slits at the back of the scoops, there is no way water can go up and into the stock snorkel onto the filters... It would take too much pressure and the water somehow not getting caught at the scoops slits, the gap between the stock snorkel and scoops, and the transitions.. its just a tale if you ask me... It rained and snoked like hell yesterday... the snorkel inside had no signs of even being wet.. Even after highway driving. |
10-31-2011, 09:48 AM | #10 |
246
Rep 3,441
yeah, what's the issue?
There has been a lot of back an forth on the scoops and I wanted to know if he felt any gains or benefits.
10-31-2011, 09:56 AM | #11 | |
149
Rep 3,552
Nice to know! maybe picking up myself a pair! |
10-31-2011, 10:39 AM | #12 |
153
Rep 3,730
They make your engine bay dirty if running DCI's, that's about it. I have them on my car, even with the closed airbox I don't notice any difference in throttle response or IAT drops. I'm up in the air on them and would not recommend them.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
10-31-2011, 11:29 AM | #13 |
246
Rep 3,441
That's what I thought....thanks for the unbiased review.
10-31-2011, 11:40 AM | #14 |
3441
Rep 79,211
They allow more air into the engine bay. A guy did a test a while back using a leaf blower (as wind).
He placed a candle where the DCI sits and blew air at the front of the car with and without scoops. Sure enough with the scoops the candle blew out. This is not any seat of the pants power gain by any means but it atleast proves it does direct air towards the cones moreso then without the scoops. I'm not ashamed to recommend them. |
10-31-2011, 11:43 AM | #15 | |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
WOW! Now THAT's the scientific approach that excites everyone around here!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
10-31-2011, 11:50 AM | #16 |
30
Rep 1,041
Well I measured an average ~2 degree drop in oil temps as well as a slight performance gain at speed (+60 mph) (Vbox measurements) upon installing the Cyba Scoops. At high speed (120 mph+) the temperature drop is even higher. I use the AFE stage 2 DCI kit, so maybe it is more affected by the scoops than a closed air box.
They do however, also add quite a bit of dust in the engine compartment though.....
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
10-31-2011, 12:30 PM | #18 |
226
Rep 2,387
If it lets a lot more dirt and stuff in it has to let a lot more cold air in. It would probably be a good idea to put some mesh on the end of the cold air inlet inside the engine compartment for those running open DCI's.
I have a set on order will look carefully at temps before/after. |
10-31-2011, 01:35 PM | #19 | |
30
Rep 1,041
I measured a ~1.5-2 mph gain in average quartermile end speed as well on my Vbox. Quite consistently actually, and the improvement was from 60 and up. For the 41 dollars I spent, I would say it's a great upgrade.
10-31-2011, 01:54 PM | #20 | |
226
Rep 2,387
Anyway $41 for some relief is a welcome break from traditional BMW aftermarket pricing. |
10-31-2011, 02:18 PM | #21 | |
30
Rep 1,041
Anyway, the FMIC will help A LOT, the scoops a little on temps. I basically live and drive at sea level, but I do remember back before I upgraded my FMIC when driving spirited through hairpins in the Austrian Alps [~7k feet altitude) how my oil temp increased another 8-10 degress over any previous use.
10-31-2011, 02:51 PM | #22 | |
226
Rep 2,387
1) Less air means things like radiators, oil coolers and esp INTERCOOLERs are less efficient, since there is less dense air to transfer the heat to. 2. Turbos have to spool up harder to hit target MAP pressures, so more heat produced. 3. More of the target MAP pressure is from pressurized air, so the air is hotter. But then go to 1) and see that FMIC is less efficient etc. Anyway in my case the oil temps got so hot so fast I decided to shut it down until I can get a better FMIC. I want to do some baseline runs and datalog but I am afraid to look at IAT's right now, so driving very conservatively. All my other cars (& bikes) are NA and are down 25% plus in power at these altitudes. One reason to get the 335 was the turbos to get some of it back. Back to the scoops, my hope is they at least counteract the likely increased IAT's due to the DCI (but better air flow), plus the better FMIC, will get things to where I can thrash it at will and not worry about oil or IAT temps. This is with Cobb stage 1 91 octane tunes. Get those reliable and I'll try the stage 1 93 octane tunes... |
