DME codes
10-29-2011, 05:45 PM | #1 |
54
Rep 740
DME codes
Hello Gents:
I have these codes I found with my COBB AP. Should i be worried about these codes? Whercan I find a list of DME codes? Any assistance is greatly appreciated THX |
10-29-2011, 05:48 PM | #2 |
915
Rep 3,456
Drives: Harrop E90 M3
Did you disconnect the battery recently? The ibs- intelligent battery sensor is part of the negative terminal. There's a blue or black connector off the terminal that might be disconnected. It's the only other connector off the negative terminal besides the cable itself
10-29-2011, 05:54 PM | #3 |
Some dude
92
Rep 1,780
Did you just find these codes because this is the first time you've looked, or did you just do something and now these codes are present?
RRT
E92 335i/6MT with stuff and things |
10-29-2011, 06:39 PM | #4 | |
54
Rep 740
10-29-2011, 06:42 PM | #5 |
54
Rep 740
I have had COBB installed for about 12 weeks now. I just checked for codes the other day and found these. I need a list or something. I didnt see these codes on the bavarian DME code list that is a stick to the sub-forum.
10-30-2011, 09:13 AM | #7 |
915
Rep 3,456
One symptom your battery is getting low on top of faults, is the clock resets, as an FYI. If you have to reset it once in a while or daily it's time. The car powers things down to try to ensure the car can start once it is low, the clock resetting is a result. If you do replace it, don't forget to haw the replacement registered by the dealer or someone who can code that into the car. Otherwise the new one may get overcharged and damaged as a result.
10-30-2011, 11:40 AM | #8 |
70
Rep 2,197
http://www.obd-codes.com/trouble_codes/bmw/
Here is a list of BMW DTCs |
