Injector TESTING and FLOW by HorsepowerFreaks using ID 2000cc Injectors
10-29-2011, 10:31 AM | #1 |
149
Rep 500
There's been some discussion about injectors on these forums so I asked John to take our new ID 2000 injectors along with some other injectors and give a tutorial on injector flow rates and spray patterns as various fuel pressures and engine rpms. At the end he will show you a lower quality injector literally shut off from too much fuel pressure.
Our higher stage 335i turbo kits will be running high impedance fuel injectors through our new intake manifold and fuel rail. Chris. |
10-29-2011, 01:44 PM | #2 |
242
Rep 2,781
Drives: E90 335i Racecar
Ah, a fuel rail for the 335i. I was wondering when someone would integrate this in!
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
10-29-2011, 02:05 PM | #3 |
164
Rep 2,875
It's about damn time! HPF, How about upgrading the HPFP? Are they going to be Pt.2 of the video? Nice job!
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
10-29-2011, 03:43 PM | #7 |
169
Rep 12,680
Drives: like an asshole
That's some solid shit
10-29-2011, 05:23 PM | #8 |
26
Rep 660
N54 need 2000cc Injectors?
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
10-29-2011, 05:31 PM | #9 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
i am pretty sure 6 of thos injectors can fill my bathtub faster than my facuet.
10-29-2011, 11:35 PM | #10 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Interesting stuff indeed! I actually surprised to see some of these injectors produce a spray pattern similar to a garden hose!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
10-30-2011, 11:31 AM | #15 |
70
Rep 2,197
This is really cool. But IMHO the best fuel system solution is upgraded lpfp,hpfp, and injectors. Keep the factory setup, just make able to handle the fuel demand. A secondary fuel rail system seems like its going to a big weak point. Remember that port meth system posted up a couple weeks ago and how very few people seemed optimistic about it? Same exact thing only this is more crucial. Im not hating or knocking on HPF, im just pointing out there is a better solution.
10-30-2011, 01:48 PM | #16 | |
General of the Armies
156
Rep 656
The only thing is the complexity it adds to an already complex engine. More points of failure, more issues to resolve, more maintenance (but it would probably fix the backside of our intake valves needing to be manually cleaned). With all this said, I'd still prefer an upgraded DI system over this setup... |
10-30-2011, 05:19 PM | #18 |
Rep 124
I ran them on my 800hp evo on stock ecu and they idle like stock.
135i with mods.
Evo 8 804hp GONE supra sold evo's sold 335i sold |
10-30-2011, 07:22 PM | #20 |
26
Rep 660
Oo ic
11-01-2011, 03:49 AM | #21 |
Rep 72
Think further down the road....
I see a lot of people moving this route when they finally decide to go E85. Obviously injectors aren't the only upgrade necessary for such a project, but these ID injectors simplify the process. Purchase one set of injectors and never look back. I've used these on other cars and their performance across the charts are excellent.
Work: '07 335i Sedan
Play: '90 300ZX (10.3@140mph) And For Giggles: 06' R1 |
