NGK plugs??
10-28-2011, 01:21 PM | #1 |
177
Rep 751
NGK plugs??
Hi
Having a nightmare with a rough idle (shakes & shivers) that started imeeditaly after changing my original plugs 18 months ago. I've had 3 sets of Bosch & BMW oem plugs, 6 new coils and 6 new I injectors. Air leak test amongst many other parts with no fix. My local Indy have advised to go back to basics and concentrate on the plugs as this was when the problems stared. They are looking to try a single prong NGK plug that some other 335i owners are using with success after miss fires on oem plugs. I believe they are from a 2008 mini cooper s and run cooler than oem plugs. Here is a link to another thread that discuss them: http://n54tech.com/forums/showthread.php?t=8470 Any experience or thoughts would be great. |
10-28-2011, 01:26 PM | #2 |
29
Rep 378
did you read the whole thread, because at the end he talks about his car shutting down and not restarting...might be better to stick with oem until there is another guinnea pig
Current: 2012 Mustang GT 5.0(Brembo Package, Jon Lund tune, steeda 101mm CAI, roush axlebacks, offroad xpipe)
Current: 2008 Honda CBR1000RR (Jardine Slip-On, PC III, dyno tuned at 173 rwhp) Sold: 2008 BMW 335i(JB4, Stett CP/Tial BOV,BMS DCI, Raceland Catless DP) |
10-28-2011, 03:21 PM | #6 | |
177
Rep 751
Seems he's using them without issue but it didn't solve his high boost misfire which is not same as my issue. Anyone else have an opp on this? Last edited by 335i E92; 10-28-2011 at 03:27 PM.. |
10-28-2011, 03:32 PM | #8 |
177
Rep 751
Its bad, at the lights the misfires shake the whole car and the idle then rises from 600 to 750 rpm. This only happened when I changed out the original plugs so it has to be a problem with plugs which is why I'm looking at as many plug options as poss. I've already tried thd bosch & BMW ones with all possible adaptation resest and it's stilljust as bad.
10-28-2011, 03:37 PM | #9 |
台灣 台北市
88
Rep 1,267
Drives: 2009 GT-R Premium
don't you think you also need to change coils??
10-28-2011, 03:43 PM | #10 | |
103
Rep 3,177
10-28-2011, 03:44 PM | #11 |
103
Rep 3,177
although the issues are different, the ngk plugs did greatly reduce the misfires. if you're not having any luck with the oem or bosch plugs, may be worth giving the ngk plugs a try.
10-28-2011, 04:10 PM | #13 |
161
Rep 7,377
You wont cure poor idle by changing to a different type of plug. The issue is somewhere else if it persists on new oem plugs.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-28-2011, 04:11 PM | #14 |
177
Rep 751
In the last 18 months since the original plugs were changed I've had 3 more new sets of plugs. Each set was in for 6 months and as time went by the idle got fractionally better but still violent.
However every 6 months straight after the new plugs went in the idle missfires went back to being extreme. I've tried very adaptation known to the n54 and not one helped. It's as though the dme got used to the same plugs for 45k and just can't adapt to the new ones. What happens when you get timing issues, is this a big problem? I really want to fix this issue but obviously don't want to open the door to a bigger one!! |
10-28-2011, 04:53 PM | #15 |
177
Rep 751
Ive spent the last 18 months reading coutless threads and there seems to be a common problem of a rough idle after changing from original plugs. Some have found fixes with adaptiaions others are just living with it and some dont get it at all.
It's a definate problem that some of our ecu's struggle to adapt to the change in plug gaps from old eroded plugs to brand new plugs. Got an ETS intercooler and AR DP's due to be delivered next week. As with most of you my car is my hobby and passion and I'm desperate to find a solution after 18 months of this BS. Until this is sorted the bolt ons will stay in the box. Surly its worth a try with the NGK or are we saying I'm playing with fire and will do more harm? |
10-28-2011, 05:17 PM | #16 | |
177
Rep 751
http://www.e90post.com/forums/showthread.php?t=391007 Have they caused you any issues with knock / timing? Are they the ones from a mini coopers s 2008? |
10-28-2011, 11:54 PM | #17 | |
56
Rep 1,311
How does the outgoing plugs look? Are they normal tan-colored, white, sooty black, burnt oil black, shows excessive gap-wear, very eroded? Depending on the answer it may be possible to trace the underlying cause. What is the mileage of the engine? Is it tuned and with what in such case? My car has 40000 miles and no issues whatsoever on idle or up in rpm independent of the engine is cold or fully warmed up. It has recently undergone a 2-step BG treatment for removing carbon and soot with the BG 44K and BG ISC products to preserve the smooth running. I have never used anything but stock plugs and replace them about every 15000 miles. |
10-29-2011, 02:12 AM | #18 | |
177
Rep 751
Everything that could effect the idle has been replaced or tested and everytime its pointing back to the plugs. Gonna try the NGK plugs next week and then possibly look at a new DME as a last resort. Has anyone any hard proof that NGK plugs are gonna butt f@&k my car? Would appreciate any assistance I can get, drivin me crazy = major understatement!! Last edited by 335i E92; 10-29-2011 at 02:18 AM.. |
10-29-2011, 02:43 AM | #19 |
56
Rep 1,311
There is no reason at all to believe a 4th swap of plugs will solve a problem that remains after 3 replacements. And the stock plugs works perfectly OK in all N54 from stock to FBO. If the car runs better after a too early plug replacement it indicates the car runs lean and needs the very last bit of energy from the ignition system, which is not normal.
Leave the car at a shop that is familiar with the N54 and they should be able to solve your problem. A faulty ECU is very low on the list for causes to rough idle. |
10-29-2011, 03:25 AM | #20 | |
177
Rep 751
It started when I changed the original plugs and has instantly got worse each time I've put fresh ones in over last 3 changes. I know that most seem to swap plugs with no problem but if you search rough idle after plug change you will see there is a community of us with this issue. I agree DME is a let resort but we are at last resort stages here |
10-29-2011, 03:41 AM | #21 |
56
Rep 1,311
You don't happen to still have the plug set that did not caused rough idle? Even though it is very unlikely that the newer sets are all faulty this could provide you with the answer.
I've seen people have thoughts the DME needs to adapt so new plugs, which is incorrect. The DME adapts to the engine as a complete unit, where the plugs plays a minor part in this respect. Basically, a plug will ignite the combustion or not, there is not a lot of variations in between during the service life of the plug. |
10-29-2011, 05:52 AM | #22 | |
177
Rep 751
http://www.e90post.com/forums/showthread.php?t=571344 Many others that have changed original plugs have developed the same rough idle as me, some have and fixed it with the resets via a BT cable in mr5's thread. So adaptation definatley play a part for some of us. Or like me the reset doesn't work and the problem persist. |
