Need Help Analyzing Cobb logs please
10-26-2011, 08:08 PM | #1 |
33
Rep 231
Hi All,
Thanks to everyone on this board, I've learned a ton in a few short weeks. Per the DIY's, I believe I have successfully created some Logs on Cobb Stage1 Sport with 92.5 Octane fuel in CA. I'd like to know if I can run Sport mode in California with 91, but I first wanted to do a run with some better gas. Attached are 2 pics I have from the DIY where I copied and pasted my results, along with 2 files attached. The first one, with the word Advanced in it, is my data pasted into the DIY spreadhseet. The 2nd one, with the word - "All" at the end, is all of the paramaters I pulled in case there is something that is needed in there I didn't put in the other one. ( I had to rename the 2 CSV files into .txt). I did try to clean it up somewhat and take out the idle time, etc. Any help in deciphering would be awesome! Thanks
Everything is just for fun, and may or may not constitue real characters in actual life... ------------ |
10-26-2011, 08:15 PM | #2 |
3441
Rep 79,211
too much going on in the first graph.
Keep it simple: RPM Boost Throttle Ignition (Pick 1 bank that may have timing drop outs) AFR (Pick 1 bank that is leaner) IAT Or Graph:1 RPM and Boost and Throttle Graph:2 RPM and Ignition Graph 3 RPM and IAT Graph4 RPM and AFR You really only want 3-4 sensors per graph. Otherwise it gets too busy. |
10-26-2011, 09:11 PM | #4 |
33
Rep 231
Mix of 100 and 91! I'll put up some Nte graphs tonight.
10-26-2011, 09:36 PM | #5 |
Some dude
92
Rep 1,780
Also helps to log just one long gear pull and one with a shift such as 3rd up to 7000 then shift to 4th. But definitely clean them up by reducing the number of channels logged in the same chart.
RRT
E92 335i/6MT with stuff and things |
10-26-2011, 11:48 PM | #6 |
33
Rep 231
I took one gear shift out of here, and took out a bunch of the other data.
Does this help any? I wish there was a DIY on how to make these charts..I'm doing the best I can. thanks
Everything is just for fun, and may or may not constitue real characters in actual life... ------------ Last edited by azeemtn; 10-27-2011 at 12:40 AM.. |
10-27-2011, 01:29 AM | #7 |
161
Rep 7,377
are having traction issues? DCT is completely off?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-27-2011, 11:03 AM | #8 |
33
Rep 231
Enrita,
DTC was not off. I see I have a lot to learn. Took me all night, but I've learned how to graph properly. I'll turn off all traction control, run a pull with 2nd and 3rd gear, and report back. Does that sound like the correct action? I am surmising the gear is not as important as the pull through the entire gear - is that correct ?
10-27-2011, 11:39 AM | #10 |
33
Rep 231
10-27-2011, 12:14 PM | #11 | |
Burrito bowl connoisseur
124
Rep 3,501
10-27-2011, 12:18 PM | #12 |
3441
Rep 79,211
DCT off all the way. 3rd gear to 4th gear is all thats needed.
2nd gear usually has traction loss and too quick of a gear. Not enough load and heat build up. The logs look ok so far so there really isnt any reason to pursue more logs unless you want to. Last edited by Jeff@TopGearSolutions; 10-27-2011 at 01:16 PM.. |
10-27-2011, 01:13 PM | #13 |
33
Rep 231
Thanks Jeff.
I'll finish off this tank, use CA 91, and then try a 3rd pull per your directions. I'll put up cleaner graphs too since I think I've got the hang of dual y axis graphing now.
10-27-2011, 01:38 PM | #14 |
161
Rep 7,377
just run 3rd gear and 4th. 2nd gear is useless...
10-27-2011, 01:46 PM | #16 |
33
Rep 231
Can I ask where you guys are doing 3rd and 4th gear runs?
10-27-2011, 02:05 PM | #18 |
3441
Rep 79,211
10-27-2011, 02:23 PM | #19 |
40
Rep 462
not many straight road in sanjose that allow speeds of in excess of 120 lol work on the suspension it looks like you have so many twistys down here in southfl we have us27 it has a 27mile straight
