What to log on Cobb?
10-26-2011, 01:19 PM | #1 |
33
Rep 231
Hi guys,
I posted this in another thread, with no responses, so I'll make a new thread. ----- I would like to run some logging and post it to see how the graphs look between my current gas and (92.5 octane), and standard CA 91 I'm running Cobb Stage 1 "Sport" Mapping with linear throttle. Here is what I think I need to log for you guys to help me read what I am getting. Can someone please add what else I may need?
Everything is just for fun, and may or may not constitue real characters in actual life... ------------ |
10-26-2011, 01:36 PM | #3 |
44
Rep 1,016
You can only log so many variables at one time though. If you try to select too many it will tell you to "uncheck" some.
Crimson Red e92 335i - H&R Premium Performance Coilovers, 19" AG m359's, Cobb AP, BMS DCI, AA CP/BOV, OEM Gloss Black Grills, M3 sideskirts
10-26-2011, 01:42 PM | #4 |
33
Rep 231
Is the list above adequate to figure out if I am running too agressive a tune for my current octane gas, or do I need to add some others to this list?
If you try to add them all, it says too many, so I figured I'd ask which ones are most important. I gleaned this from the AFR charts in some of the DIY's, but I haven't been able to find a list anywhere, even on the tutorial or videos.
10-26-2011, 01:44 PM | #5 |
70
Rep 2,197
You will want to log as few parameters at a time as possible, the more you log at once the less accurate it will be be. Do a couple seperate runs focusing on different channels
10-26-2011, 02:16 PM | #6 | |
161
Rep 7,377
Has this been confirmed by COBB? To the OP , i pretty much log the same channels. I add timing correction and short term fuel trims.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-26-2011, 02:33 PM | #7 |
3441
Rep 79,211
At a minimum:
RPM Boost TPS IAT AFR Bank 1 or 2 Ignition (maybe cylinder 1 or 6) As much as you can log many parameters some of it can be overwhelming to view in a graph. Its best to start with the simple things. The idea for many log parameters is to help with troubleshooting in case their is a problem. ie. if your not hitting boost targets you may want to look into LOAD and wastegate duty cycle or if your not hitting air fuel targrets you might want to look into fuel trims. ETC |
