BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Should i get OEM alarm for my e93?
      10-26-2011, 12:19 PM   #1
e93black
Drives: e93 335i
E93 BMW 335i  [6.34]
i like the motion sensor because i dont have to close the top when i park my car for a quick grocery shopping.
i was wondering if it is easy to install?
how much does the dealer charge?
do i have the activate by dealer?
      10-28-2011, 06:58 AM   #2
Thunder Dump
That tickles
Thunder Dump's Avatar
11
Drives: '09 328i E93 SGM/CR
If you are trying to retrofit the factory alarm for the E93 (that is, you didn't get it installed from the factory), then it won't come with the interior motion sensor--that only comes installed from the factory that way. And if your car has a build date of 04/09 or newer it's not pre-wired for it so the install cost will be prohibitively expensive.
      04-11-2012, 11:26 AM   #3
megaguirius
Drives: 2007 335i convertible
My 07 has alarm pre-wiring from the factory. I bought the (apparently super basic) "kit" and wil attempt instal sometime.
      04-11-2012, 08:48 PM   #4
techwhiz
techwhiz's Avatar
453
Drives: e90 335i Sedan - Arctic
It's quick.
Panel in the roof, switch under the hood.
Pulling the liner in the rear driver fender well takes the most time.
Had it coded by a local guy for $80.
Total cost ~$320 installed.
      04-11-2012, 10:13 PM   #5
jackass1
jackass1's Avatar
11
Drives: black 335i convertible
If your car isn't pre wired, could be pretty costly. If you get an alarm installed, you also have to buy the motion sensors. That's another 300 or so. I was fortunate enough that my car was pre wired. Got my alarm for 120 plus 300 for the sensors. And another 125 for the install from a indie
