So who sells rebuild kits for our 6hp21 AT tranny?
10-26-2011, 05:32 AM | #1 |
Rep 41
Title says all, I feel like my tranny will give up soon and Id like not just rebuild it but make stronger for all that upcoming single turbo stuff, I\'ve seen some rebuild kits for 6hp19 but haven\'t found anything for our tranny..
10-26-2011, 05:43 AM | #2 |
161
Rep 7,377
Search for my thread about level 10
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-26-2011, 09:24 PM | #3 |
74
Rep 1,543
How do you know your tranny will give up soon? How much power are you pushing, and what are your mods?
10-27-2011, 12:48 AM | #5 |
545
Rep 7,705
Are you 100% sure it's your transmission that is failing? What tune are you running? I uploaded wrong map and firmware on proceed tune once and I thought my transmission was slipping badly. Replacing/rebuilding your transmission will cost you about $4000 + labor.
10-27-2011, 11:14 AM | #6 |
Rep 41
Im FBO running 16psi w/o meth, its not slipping yet but shifts not as smooth as before, I feel like my tranny goes bad if Im gonna put upgraded turbos or some sort if upcoming single turbo kits
10-27-2011, 01:31 PM | #7 |
74
Rep 1,543
Try changing your trans fluid. Use a thicker trans fluid, than OEM, for your higher HP setup. See how that helps shifting feel.
10-27-2011, 01:51 PM | #8 |
161
Rep 7,377
you only have to worry when the trans is slipping. this happens pretty much after 450 real whp which you can only get with upgraded turbos or nitrous. try to reset your AT adaptations and service the trans. i am running Redline D6 which is approved by ZF trans and offers higher/lower temp protection than stock oem oil.
if you have a Vbox is preatty easy to see when its slipping . when it starts sounding like this than you have issues... Check the first gear change with the overreving after level 10 upgrade:
10-27-2011, 02:19 PM | #9 |
Rep 300
Enrita,
How is the driveability of your L10 box? Is there a significant downshift clunk in automatic mode, on deceleration? -Michael
DD: 2007 BMW 335i Sedan
Weekends: 2004 Porsche 911 C4S |
10-27-2011, 02:33 PM | #10 |
161
Rep 7,377
its better than stock. no clunk . very smooth . from a dig it grips straight away , very enjoyable on M mode with paddles on twisty roads.
10-27-2011, 02:39 PM | #11 |
56
Rep 1,311
10-27-2011, 02:43 PM | #12 | |
Rep 300
Perhaps they finally figured it out.
10-27-2011, 03:06 PM | #13 |
Rep 41
well I've just changed the fluid but to oem one, I'll try to reset AT adaptation for sure and see if it helps....I've seen L10 website and they sell great 6hp19 kits but they don't answering emails and I can't actually send them my core anyway since I'm living overseas..
10-27-2011, 03:09 PM | #14 |
161
Rep 7,377
from what i know my valve body is different than the other they did and they actually cunsulted with a eu zf engineer for tips. As far as i can "feel" its great . i havent pushed 500 whp yet but will test this weekend a lot on 18 psi and meth weather permitting . So far so good and with procede the car is ferocious.
10-27-2011, 03:10 PM | #15 | |
161
Rep 7,377
AGAIN you dont need to do anything with your trans on stock turbos. just service it. the stock trans is good for 450 whp no problems.
