Simple cobb dyno question 91 octane.
10-25-2011, 03:42 PM | #1 |
61
Rep 908
Drives: em-funf
Garage List 2000 E39 M5 - current [0.00]
2007 E92 335i - SOLD [0.00] 1996 E36 M3-SOLD [0.00] 2000 E39 M5-SOLD [0.00] 2001 E46 M3-SOLD [0.00] 1995 E36 M3-SOLD [0.00] |
Apparently this is REALLY difficult to find in search. Would anybody be kind enough to post a link?
I’d like to see a dyno of ’07 335i with Cobb ONLY (NOT interested in dynos with DPs and other mods). JUST SOFTWARE ON 91 octane ONLY. I don’t need that famous Cobb’s dyno from their brochure which shows stock 335i making 240whp on 91octane, as that doesn’t seem representative. |
10-25-2011, 03:44 PM | #2 |
Rep 375
Dyno numbers are just that, numbers. The Cobb dyno is realistic if you look at the delta. Its about ~70 WHP gain from stock. Whether the baseline is 100-170WHP or 300-370whp 70WHP is 70 WHP more.
10-25-2011, 03:47 PM | #3 |
17
Rep 423
Drives: E92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, 90631 La Habra, CA
It's not a 2007 but you'll see similar gains:
I've seen it anywhere around that HP level give or take about 20rwhp or so
10-25-2011, 04:09 PM | #4 |
51
Rep 923
IIRC Cobb uses a Mustang Dyno which always reads lower than a DynoJet. On a DynoJet, stock cars have around 270-280 whp. So add the 70 hp delta that Cobb gives you and you are at 340-350 on a DynoJet. There are more things to a dyno than just numbers. The delta is the only things that matters not the final number it spits out as all dynos read slightly different. There are many other factor that come into play such as, correction factor (if any), whether its displayed in SAE, Uncorrected, or STD, and type of dyno.
10-25-2011, 04:12 PM | #5 | |
17
Rep 423
10-25-2011, 04:49 PM | #6 | |
61
Rep 908
Drives: em-funf
I'm curious as I'm not sure that 91 octane TYPICALLY yields 240whp in stock form? Is that auto tranny or manual? |
10-25-2011, 05:26 PM | #7 | |
51
Rep 923
10-25-2011, 05:49 PM | #8 |
61
Rep 908
Drives: em-funf
I don't think you understand what I mean. For simplicity here it is using 100whp car:
20% increase on 100whp stock car is 120whp 20% increase on 110whp stock car is 122whp 20whp delta on 100whp stock car is 120whp 20whp delta on 110whp stock car is 122whp. Numbers differ depending what value you start from (stock form). I've dynoed cars before and understand all of them will read differently, even the same dyno on the same day will read slightly different. I just want to see what is the typical STOCK 91 octane 335i and software only 91 octane. I suspect typical stock 91 octane 335i manual is not 240whp, but more like 260whp. This is why I said I am not interested in already posted dyno from cobb site that lists 240whp value. Trying to see what other actual dyno values have customers got in this form. I hope that's clear |
10-25-2011, 06:08 PM | #9 | |
51
Rep 923
There are several Dyno charts posted in the Sticky labeled "N54 Dyno Chart Compilation" and here are a few Dynos from Cobb users showing everything I already stated before: http://www.e90post.com/forums/showth...b#post10512055 EDIT: I guess the end state I am trying to point out is that if you took your car to a Mustang Dyno that said you make 240 hp, and then immediately put it on a DynoJet one and it made 270 hp, do you really think your car made more power? No it made almost exactly the same power its just a difference of how each particular dyno is calibrated. Some read high (DynoJet) and some read lower (Mustang), but at the end of the day the car made exactly the same power. I do understand what you when you were saying there will be a difference if you are going off a %, but a % gain is not absolute when it comes to dyno's. A delta (i.e. gained 70 hp from stock) is typically consistant between the dyno's. Last edited by jdbretz; 10-25-2011 at 06:23 PM.. |
10-25-2011, 06:19 PM | #10 | |
61
Rep 908
Drives: em-funf
If 3 cars average 233whp, 252whp and 241whp then that IS different when 3 cars dyno 278whp, 268whp, 259whp. This is why I would like to see what a typical '07 335i with manual tranny sees. Is average number 240whp or 260whp. Torque converter losses will matter, maybe not significantly, but it all adds up. Thanks for the link I already looked it before. There is no data for specific information that I am looking for. |
10-25-2011, 06:22 PM | #11 |
23
Rep 647
I think what he's asking is was the cobb stock car dyno'd with 91 or 93 octane, and was it an AT or MT as they will differ in the amount of power lost through the drivetrain.
10-25-2011, 06:34 PM | #12 | |
51
Rep 923
At stock levels there isn't really much if any difference between using 91 and 93 in terms of the dyno. That comes into play at higher boost level. |
10-25-2011, 10:18 PM | #13 | |
112
Rep 4,771
It's hard to find what you are searching for because you seem to want a 2007 335i running only Cobb Stage 1, using 91 octane, and on a Dynojet. It's a very specific combination. And in the end all that matters is the delta. |
10-26-2011, 10:53 AM | #14 | |
61
Rep 908
Drives: em-funf
Percentage wise, if you say delta whp is what matters figures give different story. mustang: 240whp+70whp delta=310whp increase of 29.2% dyno: 270+70whp delta=340whp increase 25.9% This is why saying 70whp delta or x% is meaningless, because it matters which dyno you use. YES, inherently, the car produces the same power in both scenarios, but if it gives different numbers, that % or 70whp number is deceiving. ^How about I reduce criteria? How about one dyno that is not coming from MFG that shows stock 335i vs 91octane COBB ...mustang or dynojet. |
10-26-2011, 01:41 PM | #16 | |
226
Rep 2,387
10-26-2011, 01:50 PM | #17 |
3441
Rep 79,211
You guys are thinking way too hard on this.
A typical stage 1 car will gain approximately 70WHP (give or take 10). Period. Weak Octane, High elevation, high humidity, or heat will change those numbers for the worse. Better octane, lower temps, low humidity, sea level will change those numbers for the better. (There are even more external factors not even being mentioned but I'm trying to keep things simple). |
10-26-2011, 02:02 PM | #18 |
3441
Rep 79,211
IF you want to sift through here maybe you can find a dyno that helps.
From what I see dynos are ranging from 60-80 WHP. http://www.e90post.com/forums/showth...ight=cobb+dyno |
10-27-2011, 03:24 PM | #19 |
61
Rep 908
Drives: em-funf
Thanks Jeff
10-27-2011, 04:07 PM | #20 |
475
Rep 13,583
Drives: JB E92 335i
Hope this helps out!
Stock vs Cobb Stage 1 3.01 Stock(red)vs. JB4 (blue) vs. Cobb (green) 3 Cobb runs about 3 minutes between each run. |
10-28-2011, 08:07 AM | #21 | |
Rep 395
What mode was the cobb on? SPORT? Any other mods apart from tune?
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC. |
10-31-2011, 03:16 PM | #22 |
61
Rep 908
Drives: em-funf
^^Thanks. Based on stock numbers I'm assuming this is 93 octane?
