With modding comes hiccups... (throwing codes)
10-24-2011, 10:13 PM | #1 |
141
Rep 2,217
I'm getting 3 codes: (i'm out of warranty and i'd much rather fix the problem myself if i can)
P0171 "SYS 2 lean Bank 1" P0597 "Thermostat control circuit open" P2195 "02 Signal stuck lean Bank 1 Sensor 1" The first one, i have no idea what's really going on... i don't know how to run diagnostics past this point. The second one, Research tells me the $85 thermostat went bad... but where is it located exactly? The third one, I'm thinking the post-O2 sensor is giving me codes. I only took out the secondaries, which there was no sensor attached... so i'm kind of stumped on this one... **Also, where do i buy the new brake pad sensors?** P/N? |
10-25-2011, 12:37 AM | #2 |
Captain Generale
17
Rep 80
Check out ECS tuning for aftermarket parts
Probably other sites, but ECS has a good search tool:
brake sensors: http://www.ecstuning.com/BMW-E90-325...L/Braking/OEM/ Not sure about the other stuff.
2018 LBB M2: Stock for now. Adding sound deadening and ADS delete soon!
10-25-2011, 02:54 AM | #3 |
71
Rep 282
Clean your MAF and run some fuel system cleaner. As well put some Heet Water Remover in your gas tank as well. You are running lean on Cylinder 2 and the bank 1 is actually your pre-cat sensor. Bank 2 is your after cat sensor. Therefore with both of them corresponding it sounds like your MAF or crap gas. Have you had sputtering and even backfires at all? As well when you hit the gas is the car very sluggish if you get on it hard to start with?
10-25-2011, 10:40 AM | #4 | |
141
Rep 2,217
The MAF sensor is the clip-on attachment on the intake tube, right? |
10-25-2011, 02:11 PM | #5 |
141
Rep 2,217
Okay, so O'Reilly's told me to try a few things first before i waste a bunch of money taking it to the dealer...
MAF sensor cleaner... he says try this vs isopropyl alcohol because the alcohol may still leave residue behind. The oil from the aFe intake may have contaminated the sensor thus giving a "bad air" reading. "Iso-HEET" ... a bad batch of fuel (bottom of the tank) may have put water in the reservoir. Fuel Injector cleaner... i do this from time to time anyway, but all of these together may make a difference. I'll post an update next week sometime... |
10-26-2011, 02:53 PM | #6 |
Freight Dawg
104
Rep 2,103
I don't think it's a bad post cat O2 sensor. The post cat sensor just detects catalytic efficiency not fuel mixture. The pre cat sensor does that. As far as I know, sensor 1 is the pre-cat. I could be wrong; this car has suprised me before.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
10-26-2011, 03:20 PM | #7 |
141
Rep 2,217
i ran MAF sensor cleaner over it yesterday and put the ISO-HEET in the tank... i'll have to get the codes cleared after a few days to see if they light back up...
Whenever i get down to half tank, i'll throw some fuel injector cleaner in also. |
10-26-2011, 05:00 PM | #9 | |
141
Rep 2,217
As for the other codes, i had my secondary cat taken off... i haven't heard about problems with this in the past, but i was just considering the possibility |
