I Just Blew A Fuse!
05-06-2007, 07:06 PM | #1 |
16
Rep 448
I Just Blew A Fuse!
So I went to use my tire pump powered from my sig lighter for the first time. It worked when I tested it sitting in the car. So I stepped out and hooked it up to my tire and nothing happened. I tried it in the power plug in my armrest and again nothing. I don't think it is the pump since my sig lighter doesn't work (although I must admit I have never used it). Has anyone else had this problem? Manual says not to change the fuses yourself. I've always done it myself, but with the electronics in this car I am hesitant. Nevertheless, where are they so I can check them anyway?
05-06-2007, 07:08 PM | #2 | |
STEVIL Empire
218
Rep 6,297
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
05-06-2007, 07:15 PM | #3 |
252
Rep 6,664
+1
Ignition has to be on.. If you blew a fuse, they're behind the glove compartment. Take everything out of the glove box. The back panel has two screws which you turn 90 degrees and then remove. The back panel comes off, and the fuse box is exposed..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
05-07-2007, 11:53 AM | #4 |
16
Rep 448
Thanks. I did have the ignition on. I'll check the fuse. BMW manual says Max is 200 watts. The pump I was using is rated at 15 amps. 15a x 12v = 180w. That is alot but it should not have blown the fuse.
05-07-2007, 12:20 PM | #5 | |
252
Rep 6,664
BMW must use cheap fuses or something..
05-07-2007, 12:44 PM | #6 | |
550
Rep 6,563
Thanks.
under construction! |
05-07-2007, 12:56 PM | #7 | |
252
Rep 6,664
No need to knock on wood about the fuses, fuses are cheap. The hardest part is finding a neighbor with a kid who has arms small enough to fit through the glovebox to get to the fuse box..
05-08-2007, 09:46 AM | #8 |
Rep 60
So, the pinguin has some car troubles and took his BMW 335i coupe to the Arctic Auto Stop.
While the mechanic was checking on the car, the pinguin walked across the street to the Polar Ice Cream store for some ice cream. A few minutes later, he returned to the shop to hear the verdict. The mechanic looked at him seriously and said: "It looks like you blew a seal." The pinguin, offended, replied: "No sir, I just had some ice cream..." |
05-08-2007, 11:38 AM | #9 |
OEMconcept
174
Rep 5,593
i have the same problem with my OEM samsung phone charger, i've used it twice and both times, it blows the fuse..
i can use my motorola and ipod charger at the same time no problem, but the samsung by itself.... forget about it.... i know where the fuses are, i wanted to change it on my own, but on the card that explains which fuses are which, it doesnt clearly mark which is for the cigarette lighters.... could someone tell me which it is??? (by the number on the fuse chart) |
05-08-2007, 12:09 PM | #10 | |
252
Rep 6,664
Number 30. If you post a picture of it, I'll circle it in red. I had a picture of the fuse card but imageshack isn't showing it anymore.. Josh
05-09-2007, 09:50 AM | #12 |
OEMconcept
174
Rep 5,593
05-09-2007, 09:54 AM | #13 |
156
Rep 10,411
I have not had this happen on on phone charger or i-pod device but i have not tried an air pump either. I did blow a fuse o my old car with an air pump. Who knows maybe it draws too much power. Try another air pump if you anyone who has one.
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
