Replace Resonators with high flow cats Or Catted Downpipes
10-22-2011, 10:00 PM | #1 |
278
Rep 5,062
Drives: Black e92 335i
So I want to add my Downpipes back on, but I chose to run with one set of cat's at all times. I took my car into the shop to get a set of high flow cats welded into my Vanguard Catback setup, but they said there was nowhere to put it unless I remove the Resonators and put the cats into the place of the resonators.
Now my concern with this is how much raspier would the exhaust setup get? I know removing the resonators will definitely induce some rasp, but will a set of high flow cats be able to keep the rasp under control? If anyone has done something similar their input would be greatly appreciated. ORRR.... would just going with a set of catted downpipes be a better idea? The goal of this setup is for Pure sound enhancement and not performance.... I have the catless AR's for my performance needs
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
10-22-2011, 11:25 PM | #2 |
86
Rep 1,262
Do you have vanguard midpipes?
If not, since you have an E92 there is no resonator on the stock midpipes. Those are the secondary cats. Replacing them with high flow ones will change your sound a bit, but not much from what i've seen. most people do it for performance.
Josh-
10-22-2011, 11:26 PM | #3 |
278
Rep 5,062
I have a Vanguard catback not OEM.
10-22-2011, 11:37 PM | #5 |
127
Rep 6,773
Catted DPs are not worth it IMO..ur always better off removing the restriction in the downpipes..rasp, drone etc are a function of the mufflers more than anything..w that said rule of thumb is:
HFCs help drone Resonators help rasp You should prolly run both if your set on keeping the Vanguard You might also wanna look into Vibrant resonantors they make some application that are slim enuff and work w the tight space u have |
10-22-2011, 11:45 PM | #6 | |
278
Rep 5,062
Yeah, I just don't see the benefit in the catted DP's since the restriction right after the turbos is still there... so I never really considered them much.
I don't really notice any annoying drone I'm just adding the HFC's for emissions reduction... but I am worried about the Rasp that deleting the resonators might cause. If I were to run both I would have to do a MAJOR hack job on the exhaust... first I'd have to cut the resonators out and weld in HFC's... and then I'd have to cut another area of the exhaust and weld in some vibrant resonators (which I know work magic for rasp) so that start's to become a bit too expensive with the labour involved. Getting the exhaust system perfect on this car is proving to be quite a pain in the ass. Quote:
10-22-2011, 11:49 PM | #7 | |
127
Rep 6,773
10-23-2011, 12:01 AM | #9 | |
278
Rep 5,062
Wouldn't you run into some ground clearance issues with this setup? Let me know if you do go this route since I'd rather keep those resonators in there.
10-23-2011, 12:03 AM | #10 | |
278
Rep 5,062
Catless Vanguard Catless BMW PE with Vibrant Resonators These two systems sound absolutely AMAZING.... but the problem is finding room for those HFC's.
10-23-2011, 12:19 AM | #11 |
112
Rep 4,771
10-23-2011, 12:22 AM | #12 |
278
Rep 5,062
Damn, doooo it then take pics and show me where you put them haha, I need to settle this exhaust dilemna and move on haha.
10-29-2011, 07:40 AM | #14 |
278
Rep 5,062
I don't wanna be the first to cutout the resonators haha, might end up being stupidly raspy and then I'd be spending more money buying resonators and somehow welding them in.
04-03-2012, 05:24 PM | #15 |
25
Rep 699
Drives: e90 335i f30 330i g20 m340i
To revamp an older topic here...
I already have CL DPs and will be keeping the OEM catback exhaust, but I want it to be the least restrictive it can be and was considering throwing in some high flow secondary cats in place of the stock secondary cats on the stock midpipes. Is anyone doing this? If so, how are the results, if any? |
04-03-2012, 11:59 PM | #18 |
25
Rep 699
(clearly) interested in doing this as well. There are probably minimal gains to be had in replacing the stock secondaries with higher flowing cats.
Who has done this people? What did you put on your car? How does it compare? Cost, source, anything else relevant? Bueller... |
04-04-2012, 09:52 AM | #19 |
25
Rep 699
Really? No one?
04-04-2012, 03:32 PM | #20 | |
407
Rep 2,704
04-04-2012, 10:56 PM | #21 | |
278
Rep 5,062
They aren't very restrictive so you'll only be picking up a couple hp and by replacing them with another set of cats it makes your hp gains even smaller and basically negligible.
04-05-2012, 01:49 PM | #22 | |
407
Rep 2,704
So changing them to highflow will give good gains |
