doin DP install as we speak need help..
10-21-2011, 03:41 PM | #1 |
125
Rep 1,546
So I'm installing cpe catless dp's on my 335i N54..
How much room should be between were the dp meets the ehxuats? By the bolts,, I have about 2 credit cards worth of room between them.. Is that normal? |
10-21-2011, 03:56 PM | #3 |
125
Rep 1,546
Yup everything is bolted up and tight.. Just about 2 credit cars or 3 worth of room btween them, but there stiff and tight I don't see them moving juss wanted to see what everyones experience is?
10-21-2011, 03:59 PM | #4 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
As long as they're not rubbing, you're fine.
10-21-2011, 04:04 PM | #5 |
441
Rep 18,331
There should be almost no gap after the bolts are tightened...If there is then you are going to get a helicopter exhaust leak type of sound..Release the rear exhaust bracket so there is room to slide the back part of the exhaust upwards to close that small gap and then retighten the back exhaust bracket.
10-21-2011, 04:30 PM | #7 | |
441
Rep 18,331
How its feel with Dps? Here them turbos big time spool huh!! |
10-21-2011, 05:11 PM | #8 |
125
Rep 1,546
hahah Thanks man!!!! im gonna go take it out for a drive now, double check everything was tight, and everything had clearance.. wasnt a easy job and because i am so anal that didnt help any.. but i have to say the CPE's for fitment are good from what i can see.
Car is def louder. Time to go see what catless DP's are all about. |
10-21-2011, 06:57 PM | #9 |
130
Rep 2,291
I'm glad you got it done. There is a sense of accomplishment in installing your own mods. I changed my dp's in the middle of the Tx summer. Won't ever make that mistake again.
10-21-2011, 07:54 PM | #10 |
148
Rep 880
DP's are a tough DIY. As long as you got them in tight and they aren't touching you should be ok. Just make sure you don't have the clamp in the way of the wastegate arm/bolt. I made that mistake and had to basically do it all again to fix it.
10-22-2011, 12:12 AM | #11 | ||
125
Rep 1,546
Yup i double checked. i actually took pics of the sensors and the way the clmaps were on the Stock DP's then when i threw the catless CPE's on, i looked at the picture and just position the same way, everything running great. Thanks to everyone for the help. |
