Upgrade 8" woofers or add 10" or 12" sub in trunk?
10-20-2011, 03:53 PM | #1 |
13
Rep 252
Drives: 2014 F30 335i xdrive M Sport
Hey Everyone,
Debating if I should upgrade the 8" woofers under my seat or just add...1 10" or 1 12" sub in my trunk... Options are Earthquake 8" upgrade with 150 watt rms to each or 1 10" or 12" JLw7 with say 750 watt rms.... Something on those lines? Thanks |
10-20-2011, 07:13 PM | #2 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
What was your last setup?
10-20-2011, 07:34 PM | #3 |
13
Rep 252
haha I had 1 12" re audio xxx in a 2.5 cuft port 34hz a little to loud for what I want in this car....and too much space....great sub though
10-22-2011, 07:17 AM | #4 |
394
Rep 3,161
10" corner loaded sub would be perfect.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
10-22-2011, 12:34 PM | #5 |
Rep 169
I went with 8" Jehnerts under the seats and a 10" Morel Ultimo SC corner load in the trunk. Pretty happy with the way it turned out.
335d M-Sport/Everything + Individual, 550i M-Sport ED APR 2014 |
10-26-2011, 07:25 PM | #8 |
Rep 74
I recently went with the Pioneer TS-SW841D for under seats, bass is pretty good, way better than stock,install wasn't as easy as the SWS 8Xi Earthquakes, but to me the Pioneers sounded better so it was worth it. If you want a ton of bass then there is no doubt those JL W7's will fulfill that need for Bass, with that u might as well just turn off the under seat subs and just have the w7 banging in your trunk. I've heard the 12" W7 and that alone can easily bang louder than a couple of kickers, rock fords, etc..
10-26-2011, 07:35 PM | #9 | |
255
Rep 2,547
10-26-2011, 07:41 PM | #10 |
13
Rep 252
yeah I actually order a Jl 12w3v3-2 ohm and an Alpine MRP-M500..... 1 x 500 watts rms @ 2 ohm and its digital so I can put it under the rear tire cover....
I will take photo's of my install and post them.....I ordered Technics cable so it should be straight forward.... The only other subs I've had are a RE Audio 12" xxx in a 2.5 cu ft port box with a Rockford fosgate power series 1000 watts x 1 ....and a rf 12" power sub with the same amp before that....both in an explorer..... I have a VW Touareg that my wife drives and if this isn't enough bass for me I'll put it in her car and then buy a 12w6 and alpine pdx-m6.......the 12w6 and pdx were like close to $700..... and the 12w3 and the m500 was 330 shipped to my door.....and a lot of people said SQ isn't as good as 12w6 but spl is equal.... |
10-27-2011, 11:12 AM | #11 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
I didnt realise we had subs under our seats! Hmmmmm after i finish my exterior mods, i will move onto my ICE system...
I have the upgraded system from factory, but honestly... I do not think it is that good! I think the sound out of my old clk 200 was a little clearer. |
10-27-2011, 12:22 PM | #12 |
13
Rep 252
Well my old system I had MB Quartz premium 6.5 comps in the front and 6 x 9's in the rear.... Alpine something head unit I forget... and then a Hifonics Zeus amp power the mb's and this was with the RE xxx.... It was a very nice system... It sounded amazing but also was very loud....My friend had a 13w7 and the RE xxx was much louder and sounded clearer to me....My friend was pissed because he spent way more money than I did...... and I was bouncing quarters off the roof of my explorer....
10-27-2011, 01:12 PM | #13 |
Rep 74
Interested in hearing more on what was involved in getting those pioneers under the seats? Could you tell us what you had to do?[/QUOTE]
I had to cut up, the stock sub enclosures under the seats because the pioneer is bulky, I used a dremel to sand down some of the sides to make it fit, and since the floor pan and the plastic lining under the hood was almost in direct contact with the speaker, I used fatmat to cover that up, because without it the speaker would rattle up against that plastic the fatmat deadened that. Then I just places the enclosure a long with the sub back in and bolted down the seats, the subs don't stick out a lot but they did rattle the stock speaker grill so I just took them off, I'm planning on fiberglassing the enclosure to seal it back up, but as of now the speakers sound great. En though they're only partially sealed. |
10-27-2011, 04:44 PM | #14 |
50
Rep 405
I went with the sws8 also and powered them with a fosgate p300 amp. I was very impressed with the base just from upgrading the speakers powered by the fosgate is a huge difference from stock. Now unless you're looking for the kind of bass that rocks the car next to you this isn't it. But its very clean sound and compliments the logic 7 pretty good. People do think I have a box in the car when I pull up with music playing and can't believe it's coming from underseat woofers. If you do a search in the stereo section you will find a ton of info. It's just about plug n play without cutting or splicing into any factory wires.
10-29-2011, 03:04 PM | #16 | |
687
Rep 6,845
Real men use 24s http://shop.mtx.com/p/l_230/MTX_Audi...r/listing.html Only problems it weighs 369lbs So if you want 2, you're gonna have to put some weight in the front if you want your car to stay horizontal
10-30-2011, 01:51 AM | #17 | |
Rep 3
Drives: Black 328i E90 w/black leather
Any opinion is welcomed |
10-31-2011, 11:17 PM | #18 | |
20
Rep 266
http://www.cardomain.com/ride/390699...edan-4d/page-2 page 3 for my old setup (2 12 w6's on 1000.1) |
10-31-2011, 11:49 PM | #19 |
394
Rep 3,161
Do 15's :-D
11-01-2011, 08:08 PM | #20 |
13
Rep 252
haha
