Exhaust/Tailpipe question
10-20-2011, 08:08 AM | #1 |
208
Rep 3,175
Figured you guys would know considering many of you have aftermarket exhaust.
Having a cat-back stainless steel exhaust installed which will have 70mm tubing running to the muffler that will have a 3" in/out. I am trying to figure out what's the best diameter tailpipe coming off that 3" muffler output. Was looking to do either a 3" or 3 1/2" round pipe (no quads) either of which I think would better fill the bumper cut-out, 3 1/2" obviously filling it out the most. My question is, in your experience how much does the diameter of the actual tailpipe affect the exhaust note if at all? I am shooting for an exhaust sound that will be deep/throaty at the higher RPM range as opposed to a fart-can/tin sound. Any input is much appreciated. Chris |
10-20-2011, 08:58 AM | #2 |
441
Rep 18,331
Whatever you get really won't help the farting sound as most will have it unless you weld into the midpipes resonators. Resonators eliminates the raspy farting sounds dramatically
10-20-2011, 11:55 AM | #3 |
15
Rep 363
the size of the tips is not going to effect the sound, the sound is produced by the mufflers/exhaust. you could always remove the 2ndary cats and resonator if you wanted to make your car louder, but it will make your car raspy. there are videos on youtube that you can watch to hear how it sounds.
10-20-2011, 12:33 PM | #4 | |
208
Rep 3,175
Given the emissions system found on the d, removing the cat, dpf is not an option until a reflash is available. In which case I am stuck with a cat back system. Generally our exhaust note is MUCH quiter than the 335i, almost non existent in fact. So I am hoping to find a way to improve the note. Perhaps a larger diameter pipe (3") from the cat to a resonator instead of a muffler will do the trick? |
10-20-2011, 04:46 PM | #5 | |
21
Rep 549
10-20-2011, 06:41 PM | #6 | |
208
Rep 3,175
10-20-2011, 06:46 PM | #7 |
17
Rep 423
Drives: E92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, 90631 La Habra, CA
I'd probably suggest going around youtube and listening to what is available out there if I'm honest. That way you can get a good feel for what is available on the market and what you think sounds the best.
