Hard shifting 07 automatic
10-18-2011, 06:14 PM | #1 |
36
Rep 1,054
I have 80k on my tuned automatic and it seems to be bumping a bit when it downshifts. Also sounds like a clutch slip when going from 3rd to 4th gear. I have reset the drive by wire( used to work well) but it seems to return to bumpy downshifts quickly after. The trick is, BMW knows the car is worked over. They pick and choose which warranty work they will do on my car so there is no benefit to removing the mods. It\'s just more wear and tear on clips, bolts, an hardware. It makes more sense to leave it as is and pay when they say pay. Any thoughts??? Besides picking up the new 1M.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
10-18-2011, 06:41 PM | #3 |
45
Rep 1,754
+100 this would be the first thing I'd try -- the 100K mile service interval is BS, IMHO.
Be sure and change the pan, which contains an integral filter. Because you can't drain the torque converter, you still won't get all the old fluid out, but it should make a big improvement. |
10-18-2011, 07:28 PM | #4 |
21
Rep 364
Bad contacts in the pins and wiring in the mechatronic sleeve is a possibility too. When changing ATF and pan/filter, take a look at the mechatronic sleeve to make sure all pins are making contacts and the sleeve is not leaking.
10-19-2011, 10:06 AM | #5 | |
74
Rep 1,543
10-19-2011, 11:18 AM | #6 |
3596
Rep 10,358
Contact a ZF rep in your area to inquire about a complete change. The 100k mile OCI is for normally driven vehicles. You have a tune so I will guess you flogged the car fairly well. In this instance ZF recommends an OCI of approx 60k miles. You're over.
10-19-2011, 04:23 PM | #7 |
253
Rep 7,089
Drives: '06 AW 330xi
10-19-2011, 08:01 PM | #9 |
45
Rep 1,754
10-19-2011, 08:02 PM | #10 |
74
Rep 1,543
I haven't even changed mine yet. I'm waiting to go over 120K before i do it. The second drain and fill is just to ensure that all 11 Liters gets changed, even the stuff in the heat exchanger. That's why I drove mine around for like a week, first. After doing quite a few of these, my trans fluid went from burnt black at 50K to crystal clear at 86K, with tons of track days and zero shifting issues.
