Change 325i engine into 335i engine.
10-18-2011, 01:01 AM | #6 | |
Rep 300
If you want an N54, buy an N54. It will cost less and you'll be happier with the result.
DD: 2007 BMW 335i Sedan
Weekends: 2004 Porsche 911 C4S Last edited by Skydive; 10-18-2011 at 10:38 AM.. |
10-18-2011, 08:53 AM | #7 |
127
Rep 1,604
You can do a intake manifold swap from a 330I and get a tune for a pretty decent bump in power, but its still no 335. Search for info.
2014 Alpine White 328i M Sport | M Performance Exhaust | M Performance Front Splitter | M Performance Carbon Fiber Spoiler | M Performance Grills | M Performance Pedals[/SIZE]
______________________ |
10-18-2011, 12:03 PM | #8 |
83
Rep 2,291
This would require different cams, the addition of turbos, a different exhaust manifold and intake, a wastegate setup, an intercooler and a completely different ECU. A different fueling system also comes into mind. So no, there is essentially nothing similar other than the fact that both are Inline 6's (NOT V6's)...
In other words, trade in your car for a 335i or you are wasting money.
2jZ + RB26 + 4G63 + LS9 + N54 =
10-18-2011, 12:29 PM | #9 | |
3441
Rep 79,211
10-18-2011, 12:41 PM | #10 |
Joint Chiefs of Staff
4920
Rep 115,999
11-07-2011, 01:04 AM | #16 |
25
Rep 699
Drives: e90 335i f30 330i g20 m340i
The N54 does not use the second generation Valvetronic technology found in the naturally aspirated N52 and the newer (single) turbocharged straight-6 N55.
The engine block of the N54 is similar to the older generation BMW M54 engine - all aluminum with cast iron cylinder liners. This is because the newer N52 aluminum-magnesium engine block was not deemed as suitable for turbo-charging Per wikipedia... may be another reason if all the above isn't enough |
11-07-2011, 02:54 AM | #17 |
Professional Moose Racer
316
Rep 7,509
Sounds like a bolt on job to me.
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
