Jlw3 jx250
10-16-2011, 08:23 PM | #1 |
380
Rep 988
Jlw3 jx250
Hey guys I just got a jlw3 sub and jx250 mono amp and it just sounds crackely and distorted so I'm not sure what's wrong I had a stero shop install it. Thanks for any input
10-16-2011, 09:24 PM | #2 |
300
Rep 3,969
Ask for your money back and let real professionals help you this time...
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
10-17-2011, 12:54 PM | #3 |
289
Rep 3,201
Kai is right, even though he is being as flip as I usually am. Your 2010 has a complex system, even though it's probably base Stereo, and the folks who worked on it did a bad job. If they charged you money, they should fix it. However, if they knew how to fix it, they should have fixed it before rolling the car, so you probably got their best shot already, and it was weak sauce.
You need to know if you have base Stereo or HK, and you need to be clear on what you're doing to the system to upgrade it. If you have base Stereo, adding a sub only is sort of a waste of time, you go from sounding like ass to sounding like ass with a lot of bass - and that probably sounds like ass too, even though it's loud. We might or might not have a product that you would be interested in, I don't know, but asking online folks to fix a pro's problem for free is a bad call, because you should not be fixing their screwups - and because there are a myriad of ways to screw this up and we don't know which they picked. |
10-17-2011, 03:50 PM | #4 | |
380
Rep 988
10-17-2011, 04:03 PM | #5 |
300
Rep 3,969
There are plenty of examples on the forum of how a trunk sub was added successfully to the L7 system. It all starts with either a proper line output converter or an amp that can accept the outputs from the Logic 7 amp. From there on it is simple as pie.
10-17-2011, 04:12 PM | #6 |
380
Rep 988
Thanks I thought they would be able to handle the job but guess not.
10-17-2011, 04:18 PM | #7 | |
380
Rep 988
Thanks |
10-17-2011, 04:57 PM | #8 | ||
300
Rep 3,969
10-17-2011, 07:22 PM | #9 |
289
Rep 3,201
The entry-level JL amps don't have the 8V balanced inputs that all the others have. I'm surprised it sounds like this, might not be a structural design problem, might be a bad install problem or a really cheap line-output-converter. With an HK system, adding a sub is a common approach and not terribly hard to implement.
To properly diagnose it, I would need to know what they did. Hence, recommending you return to the install shop. |
10-17-2011, 07:30 PM | #10 | |
380
Rep 988
