Vishnu NJ Dyno Day (from last weekend)
05-03-2007, 11:03 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Finally found my memory stick!
Last weekend, I was in NJ to tune a bunch of Evos. We managed to sneak a few 335s in as well. The results are below. ALL the dyno runs, in order, are shown for each car. They are not hand-picked. No tuning was conducted. All cars ran the base v1.45 map. All cars were 100% with the exception of the PROcede. All 6MTs. All PROcedes were installed on the dyno between runs #2 and #3. All ran on 93oct. Hyper M3's 335 Stock vs. PROcede Fernando's 335 Chuck's 335 Just for kicks, here are all the baseline runs (of all 3 cars) on the same graph: And here are all the PROcede runs (of all 3 cars) on the same graph: Cheers, shiv Last edited by OpenFlash; 05-03-2007 at 11:48 PM.. |
05-04-2007, 12:20 AM | #2 |
44
Rep 1,568
Shiv, why is it that the post Procede HP results are so diverse, at least as far as the bottom and top range is concerned, but the base dyno is not, i.e., within 1-4 HP range? I don't see why with a base range of 1-4 the Procede range is 2-13 HP among all the cars?
P.S., I figured out my problem loading the 1.45 map--I didn't plug the f'in cable well enough into the Procede. Dumb. |
05-04-2007, 09:59 AM | #5 |
22
Rep 617
05-04-2007, 10:36 AM | #7 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Well, as embarrassed as I am for my low numbers, you can see why. The highest numbers are produced when the throttle is pressed sooner. Therefore getting the turbos to spool up quicker.
My run didnt have throttle pressed until after 2100 rpm. The highest was Fernandos and his throttle was pressed around 1800 rpm. Thats 300 rpm difference. I think if all the runs were started equally, the difference wouldnt be as great.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
05-04-2007, 10:59 AM | #8 | |
96
Rep 2,587
05-04-2007, 11:13 AM | #9 |
342
Rep 6,188
I just installed a boost gauge the other night and the highest I saw was 12.9lbs boost.
13 HD FatBob
05-04-2007, 12:24 PM | #10 | |
35
Rep 563
Love my car even more now!! |
05-04-2007, 01:08 PM | #11 | ||
274
Rep 6,510
shiv, any thoughts on why the ECU needs to adapt to the new power? Is it because after the PROcede the car has a different efficiency range? |
05-04-2007, 01:40 PM | #12 | |
558
Rep 6,169
I've heard several people said that after 200 miles of hard driving, the car starts to show it's real powers with the PROcede installed...i'm hoping this is the case since mine don't feel like "Lightspeed" ?
MKIV 6spd 1000hp Club |
05-04-2007, 01:44 PM | #13 | |
274
Rep 6,510
The only thing I can think of is that the ECU figures out that the engine is operated more efficiantly, and pulls back some of its safety measures |
05-04-2007, 01:57 PM | #14 | |
96
Rep 2,587
05-04-2007, 04:20 PM | #15 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
Good question... i'm interested in the answer also.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
05-04-2007, 06:46 PM | #16 | |
Rep 199
First of all, there is nothing to be embarrassed about. These are all impressive numbers. I notice that the graphs of the other two cars have a bump where peak torque takes place at around 2200/2300 RPMs. Your graph does not have that "bump" in the line. I wonder if that has something to do with the throttle action you describe above? Your Torque numbers from the mid-2's to 4K seem a bit higher than the others. |
05-04-2007, 07:26 PM | #17 | |
153
Rep 5,780
I was suprised that all were within 12 WHP of one another. |
05-04-2007, 08:54 PM | #18 |
342
Rep 6,188
Im interested in figuring out what the other guys were running in terms of fuel to see if it makes much of a difference.
I was using Shell 93, dynoed on new full tank.
13 HD FatBob
05-05-2007, 08:14 AM | #19 |
35
Rep 563
05-06-2007, 02:36 PM | #21 | |
327
Rep 4,484
I'm no dyno expert so this might sound stupid, but really only someone who owns a dyno and has tested this would know for sure...BUT maybe the fact you filled your tank affected the dyno results. A full tank of gas weighs about what 100-110 pounds? A 1/4 tank of gas weighs like 25 pounds. Maybe the extra 75 pounds in the car, over the rollers affects the dyno results?? The other thing is, miles (break in). Some cars might of just had more break in miles than yours. There is also just engine variances. Some cars are "ringers" others underperform by a touch. It's luck of the draw, but there's nothing you can do about it. My sedan was a strong runner, my coupe might not be as strong, it's a chance I took. Did everyone also have stock wheels/tires? Aftermarket wheels/tires might affect the dyno results a bit too. |
