BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Choose Torue or HP?
      05-03-2007, 10:47 PM   #1
LACA335i
LACA335i's Avatar
175
Drives: E92 335i coupe Black AUTO
2007 335I SEDAN  [0.00]
Choose Torue or HP?
If you want to race your car for 1/4 or 1/8 mile you want torque. If you want to cruise or do track or circus, you want HP. Torque = quick launch. HP = Long Drive endurance. anyone wanna make a comment on that?
      05-03-2007, 10:48 PM   #2
SoCal335i
14
Drives: 2007 E92-TT Jet Blk Coral Red
hey you should post some pics of your car bro, i wanna see it.
      05-03-2007, 11:06 PM   #3
Spool
Spool's Avatar
Vietnam
558
Drives: A few
I would trade my Torque for more HP anyday...we don't have wide enough tires to use all of the torque right now so it's pretty useless...
Flip it around, i'd take 380HP and 330tq as opposed to vice versa...
MKIV 6spd 1000hp Club
      05-03-2007, 11:16 PM   #4
Stein
Stein's Avatar
12
Drives: 2011 M3
Hondas do fine without torque!
      05-03-2007, 11:17 PM   #5
LOLrance
The Law.
LOLrance's Avatar
Taiwan
301
Drives: BMW
Lotus does fine without both!
      05-03-2007, 11:19 PM   #6
Stein
Stein's Avatar
12
Drives: 2011 M3
The US spec Elise is a low torque high horsepower motor, weight is it's friend.
      05-03-2007, 11:21 PM   #7
Fartpimpson
Fartpimpson's Avatar
292
Drives: E92 335i
2007 E92 335i  [0.00]
I live around where you live. Have you sign in to our socal e92 owner list? The link is in my sig.
      05-03-2007, 11:27 PM   #8
LACA335i
LACA335i's Avatar
175
my car?. it should be on my garage profile.
      05-03-2007, 11:28 PM   #9
LACA335i
LACA335i's Avatar
175
nope not yet? why ?? what happen? did i missing something?
      05-04-2007, 12:02 AM   #10
jon@themshop
jon@themshop's Avatar
38
Drives: BMW
There is a saying "horsepower sells motors, but torque wins races." - Carroll Shelby
A good example are those 335i's that got 1st and 4th at the 12hr Bathurst race w/PROcede's in them.
      05-04-2007, 02:44 AM   #11
bnj
14
Drives: e92 335i
Ah, ever Carroll has been misguided. No wonder this stuff must be corrected all the time and it emerges again and again.
Bathurst cars were running Procede map giving max torque at around 2000 rpm. I would like to have seen the smooth and silent win without the extra noisy tones of 3000 - 7000 rpm. Basically people racing their cars should put something under the throttle so that they do not happen to press pedal to the metal by accident and flip the rev range to max hp range instead of max torque.
      05-04-2007, 02:48 AM   #12
edgarj
edgarj's Avatar
32
Drives: 335i e92
      05-04-2007, 02:55 AM   #13
bnj
14
Drives: e92 335i
The average hp numbers you employ, determines the performance. Technically it is the integral of hp under the employed rev range.
When people say torque matters, one can agree with them as far as they mean that the hp curve stays up for a reasonably wide rev range and from early enough.
E.g F1 cars have a lot of hp, but very little torque. That's an extreme example but from that we can understand that using revs well beyond 20 000 one is able to turn the max hp into maximum torque at the wheels by using appropriate gear.
      05-04-2007, 03:33 AM   #14
ward
155
Drives: F
horsepower is a function of torque
they're related, you can't have one without the other
      05-04-2007, 04:02 AM   #15
bnj
14
Drives: e92 335i
They are related, yes. Power = torque x rpm
So basically you cannot avoid having them both, except by either employing low revs when you have a lot of torque, but not much power, or high revs, when you have a lot of power, but less torque.
      05-04-2007, 04:16 AM   #16
Mantis64
Belgium
Drives: BMW F31 330D MSport
2013 BMW F31 330D  [10.00]
2009 E92 325D  [10.00]
horsepower equals torque (in ft-pounds) times RPM divided by 5250,
so a high revving engine with low torque can still have a high max HP.
For example my 320D has 440NM = 324lbs/ft, but since it's a diesel and doesn't rev higher than 4750RPM, it only has 205HP. (yes it's chipped)
The 330i makes 255 hp at 6600 rpm, with only 220 lb-ft of torque
(looked that one up)
I like lots of torque, really kicks you in the back
      05-04-2007, 04:58 AM   #17
bnj
14
Drives: e92 335i
It is the hp that kicks you in the back. You have much more hp in low rpm than 330. At low speeds the hp advantage that diesels have at low rpm feels so great, because the absolute acceleration in G's is high.
0-60mph 330 is faster though, since in max acceleration, top hp rev range is used.
      05-04-2007, 05:07 AM   #18
NFS
NFS's Avatar
275
Drives: M340i
There is an element of truth to this, but it is an oversimplification.
Torque is the rotational force which turns the wheels. Acceleration is greatest when wheel torque is greatest.
Horsepower is a function of torque which takes into account time .. in engines time = rpm. So HP is a measure of torque and the rpm at which it occurs.
If a vehicle has high HP and low torque it is likely to have a relatively high revving engine. These sort of cars need to be worked hard to ensure that the engine stays in the powerband.
Cars with high torque and low hp are likely to be powerful low revving engines, like diesels and old v8's.
To consider 1/4 mile performance you have to look at gearing. Strong levels of torque at high rpm (i.e. high horsepower) are seriously useful because this torque can be geared down and effectively multiplied to produce LOT's of wheel torque in low gears.
Your statement would probably be true of a vehicle with only one gear. However it would not apply as a rule of thumb to a vehicle with gears.
      05-04-2007, 07:16 AM   #19
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
TQ and HP are always the same at 5252 RPM
HP = TQ*RPM / 5252
TQ can be described as the engine being able to maintain high power output at lower RPMS...
HP can be described as the engine being able to maintain high power output at higher RPMS...
But either way, the numbers are just calculated from eachother, so technically you want both numbers to be high for the best power band, and a nice flat output curve...
high HP cars with low torque numbers require high engine speeds, and have a smaller powerband, and high torque engines with lower HP have a smaller powerband.
short story... you want both!
      05-04-2007, 07:23 AM   #20
sdiver68
Expert Road Racer
59
Drives: 07 335i e90, 09 335i e93
I raced an 85 TQ, 110 HP TL-1000 versus a 65 TQ, 115HP GSXR750 in a long series of straight line races. Similar total weight, the TL being a torquey twin and the GSXR being a rev monster. We did 0-80, 1/4th, 1/2 miles, 1 mile and a bunch of roll-ons.
Almost without exception, the GSXR won the races. The only exception was a 6th gear pull from 40-80...we were about even. This also dovetails with my pro road racing experience, where torquey twins were almost always outclassed by their 4-cyl class equivalents. Twins do well in World Superbike, but they are also given a weight advantage...
I'll take HP. Though power under the curve is the best measure, it is hard to quantify.
      05-04-2007, 07:33 AM   #21
turbocoins
turbocoins's Avatar
18
Drives: '08 Z06, '07 MKZ
HP = TQ*RPM / 5252
Excellent summary for a street car. A broad power band will employ both good TQ and good HP. If you have one without the other, you will either have a TQ monster that can't rev, or a HP monster that has no low end grunt.
Unfortunately, the 335 i leans toward the former with the small fast spooling turbos, which is why it doesn't compete better with the near super cars.
