330i 6MT Tranny Juice
10-13-2011, 07:24 PM | #1 |
92
Rep 1,456
Is there a fluid level sensor in the tranny tied into the BC?
If not is the only way to check level by crawling under and checking fill plug? After all of these years of this vehicle being around, what is the general consensus for the best fluid to refill it with? Would like to drain and refill, and have a suspicion it is low on fluid. Thanks. |
10-14-2011, 04:54 AM | #2 | |
49
Rep 752
2001 Chevy 2500HD Duramax
2003 VW Jetta TDI 2012 BMW F800GS 2024 BMW M2 BSM 6MT Carbon Package |
10-15-2011, 03:29 PM | #3 |
40
Rep 818
No sensor, checking the level at the fill plug is the only way.
For PA and colder winters, RedLine D6 ATF is the best, you'll need 2 qts. There's a DIY in that sub-forum. |
10-30-2011, 07:06 AM | #4 |
Rep 64
I did the Redline D6 this spring. You'll need a pump, a cheap hand pump works. Of course, the gear box is maybe marginally less notchy with the Redline, so don't expect any magical change from OEM.
