BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > I need help!! What disk do I have!?
      10-12-2011, 03:26 PM   #1
Cryingsuns
You lack creativity...
Cryingsuns's Avatar
19
Drives: 335i Manual....
I'm trying to buy some Work rims for my car but I don't know what size disk I need or have. Does anyone know what size disk I have or need? I own a 2008 335i Sedan...e.
Thanks!
      10-12-2011, 03:45 PM   #2
mike3000fl
No_Country
138
Drives: 06 330i
what is a disk? the rotor?
      10-12-2011, 03:54 PM   #3
Cryingsuns
Cryingsuns's Avatar
19
I guess it's the distance the rim sits away from the rotor or something, I'm not very versed in this area. Little or no knowledge at all.
      10-12-2011, 04:08 PM   #4
edirtaynine
81
Drives: e92
thats called "offset"... you'll see it marked/stamped/sticker on the wheels with it saying "ET 30" or some other number.
      10-12-2011, 04:21 PM   #5
Cryingsuns
Cryingsuns's Avatar
19
It's not the off-set, I know what off-set I need...there are couple of things that you need to consider when making a rim purchase..I could be wrong but there are usually 3 different types of "disc" size or whatever
Rim width
Rim size
Off-set
Disk(c) size (I'm stuck on this one)
      10-12-2011, 05:21 PM   #6
mike-y
just another bmw douche bag
195
Drives: 1.9L of fury
hmm.. the only other measurements I can think of that you haven't listed is the bolt pattern for the hub (like 5 x 120mm), or the size of the center bore.
never heard of disk size, unless you are talking about brakes
      10-12-2011, 05:40 PM   #7
Cryingsuns
Cryingsuns's Avatar
19
Forgot to throw in the PCD thanks!
Look at the ad on this thread there is A disc and L disc, that's what I'm talking about. I mean do we have large calipers or regular ones? How much bigger are they then like brembo? High pad, mid pad?? lol.
http://www.e90post.com/forums/showthread.php?t=517121
      10-13-2011, 03:23 PM   #8
Cryingsuns
Cryingsuns's Avatar
19
Bump..
      10-15-2011, 05:54 PM   #9
Cryingsuns
Cryingsuns's Avatar
19
? Anyone
      11-06-2011, 06:45 PM   #10
FLOSS
Philippines
90
Drives: E46 M3
Suppose to use an "A" disk for the front
for Big Brake clearance, and "O" disk in
the rear. O disk has a smaller and thinner
back pad so u can have a bigger rear
lip. Some folks run "O" disk in the
front (u can only do this if u do NOT
have, and will not run a BBK) so that
they can also run a bigger lip in their
front wheels.
make sense??
      11-06-2011, 07:00 PM   #11
Cryingsuns
Cryingsuns's Avatar
19
front wheels.
make sense??
Thanks for the info...I'm actually not using a BBK nor will I in the future, really have no need. I am using the "O" disk in my front 19x10 +20, and will be using the "A" disk in back with 19x11 +20...That's my plan, and I'm sticking to it.
Seriously tho, thanks alot for info. No one really had any good info on this, anywhere.
      11-06-2011, 07:04 PM   #12
FLOSS
Philippines
90
Drives: E46 M3
^^ A disk will give u a smaller lip
due to a bigger back pad...
So, are u sure u want a small lip
in the rear tho??
