TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > FRM Retrofit Coding
      10-10-2011, 10:30 AM   #1
._.
74
Drives: BMW
FRM Retrofit Coding
Anyone code their own FRM2/3 module and willing to post a DIY? From my understanding you code the FRM module to your car and then change your build date in your VO?
      10-19-2011, 02:53 PM   #2
coding@ltbmw
Drives: e90 335i
What are you trying to do? What is the production date of your vehicle
      10-19-2011, 03:09 PM   #3
._.
74
Drives: BMW
I have a 11/06 build, I want AE DRL, possible a LCI tail retrofit down the road.
      10-19-2011, 04:49 PM   #4
coding@ltbmw
Drives: e90 335i
Ok so you have FRMFA, known as FRM1. AE DRL requires NFRM/FRM2.
LCI Tail Light retrofit is fine with FRMFA.
I think you should just stick with your FRMFA unless you can find FRM2 for less than $100.
      10-20-2011, 08:47 AM   #5
TigerJK37
TigerJK37's Avatar
Drives: Alpine white e90
+1 however a lot of people with FRM1 are hardwiring AE to a constant power source such as cig lighter.
      10-20-2011, 10:15 AM   #6
._.
74
Drives: BMW
I would rather a clean OEM solution not a hack with additional wires running around.
      10-20-2011, 11:14 AM   #7
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
It can be done. I have gone from an FrM1 to FRM 2..
Basically:
- you need to install the new frm
- use win kfp to program the module to your vin
-tool32 to write the vin to the module
-go to ncs expert, write the cas vo to the nfrm module
-go back (where it says cas, frm,nfrm) and select nfrm
-validate that it shows your vin and vo
- you will then have to simulate the new module (only needed for frm 2..frm 3 does it automatically)
-in the vo just remove your production date and put 0307 click ok
-the read your nfrm module and code the module using expertmode profile.
-this will load all default values into the new nfrm module and your done
-just remember to simulate the 0307 production date whenever you want to code the nfrm
      10-20-2011, 11:18 AM   #8
coding@ltbmw
Drives: e90 335i
LCI Taillight Retrofit with FRM2 or FRMFA requires re-wiring, but no new wires running around.
If you consider disabling bulb checks hacking, then yes, there is hacking
      10-20-2011, 12:14 PM   #9
._.
74
Drives: BMW
for AE DRL with my current module I would have to run wires, that is what I am referring to.
      10-21-2011, 09:08 AM   #10
TigerJK37
TigerJK37's Avatar
I agree. I was just giving you a idea of what others are doing. Only other way is upgrading to FRM2/FRM3
      01-26-2012, 10:36 AM   #11
srohang1
13
Drives: E90 2006 325i
Basically:
Thinking about doing a FRM2 retrofit in my 06. Does anyone know if there is limit on the amount of times you can code/program a FRM2/3 module before it gets bricked? I remember reading something about this, but cannot seem to find it...if someone can confirm this, that would be great.
      07-09-2013, 08:51 AM   #12
BoogeyMan'sBMW
BoogeyMan'sBMW's Avatar
Bangladesh
118
Drives: SLOW
I believe its 15 times
      07-19-2013, 06:33 PM   #13
doogee
doogee's Avatar
748
Drives: '08 M3, '09 328xi Sport Wagon
Basically:
Would you mind going a little deeper into the Tool32 step? I'm new to it and don't know how to change the VIN.
Thanks
      02-25-2017, 09:47 AM   #14
flowserver
Drives: Bmw 335i E90 2007
I have build 03/07 E90, in winkfp I have FRM2, but I donīt have this function, can I follow the same steps to activate the assistant automatic high beam?
