DIY - Enable Shift Suggestion in 6MT
10-07-2011, 08:11 PM | #1 |
782
Rep 914
Drives: Silverstone E92 M3
Before i coded this i was looking for a video online. i didn't find one so here you go..
To enable the Shift Suggestion follow the google doc spreadsheet: Modify the KOMBI module. SP_ANZEIGE -> aktiv SCHALT_PKT_BC -> aktiv Happy coding!
2008 SSII E92 M3 | LCI CIC, Apps, Tails| MPE | BBS Ch-R
1990 325i Sold- 2011 335i Sedan | 6MT | Wavetrac | Eibach Pro | CDV delete | Cobb | BSW Sudden death - 1970 BMW 2002 |
10-09-2011, 05:50 AM | #2 |
Rep 24
In my BC I can enable/disable gear suggestion by holding the BC button for a while when the BC choice is on 'nothing' (not average speed, not average consumption, not driving distance).
01-30-2012, 10:08 PM | #3 |
782
Rep 914
That must be a European feature. I tried your suggestion after i reset my ECU and i was unable to turn this back on without code
02-23-2013, 05:50 PM | #5 |
33
Rep 648
What am I supposed to see? I changed those parameters and an up and down arrow popped up on the top left of the window in the instrument cluster but they didn't do anything even near redline.
02-24-2013, 06:48 PM | #6 |
782
Rep 914
Yes.. The two little triangles suggest shift points. If the up arrows visible, up shift. If the down....
02-24-2013, 07:17 PM | #7 |
594
Rep 4,488
FYI on M3s this feature only works when in Normal throttle mode. I've seen other cars that show the arrows but don't display suggestions, not sure why though.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
02-24-2013, 08:42 PM | #8 | |
33
Rep 648
02-26-2013, 05:55 PM | #10 |
16
Rep 145
Its also easier way... Just use stak to go to some place in menu that is blank, no avg fuel consumption or milage on tank just blank page, then press stalk button ( the one you change menu) and hold it until you see arrows No need for coding
02-26-2013, 10:59 PM | #11 | |
33
Rep 648
02-26-2013, 11:19 PM | #12 | |
442
Rep 18,331
Both arrows are suppose to show up but when the DME tells you to shift there will be a number corresponding to the shift suggestion |
02-28-2013, 04:36 PM | #14 |
Rep 101
Same here, no gear number appears no matter how hard I push it. Just two arrows
02-28-2013, 06:23 PM | #15 |
19
Rep 177
Drives: 2011 335i E90 LCI
The video by OP doesn't work, but I assume it looks something like this?
It seems kinda off... shift to 4 going at <30? lol. I'm going to try it tonight. |
02-28-2013, 10:23 PM | #16 | |
38
Rep 936
03-01-2013, 03:40 PM | #17 |
Rep 101
I´ve been driving the car with these arrows for amost a month and no gear number comes up.
What do you mean by normal throttle position? I drive as I normally do, easy on the gas and sometimes a bit harder on the accelarator, but nothing happens Maybe it's a model thng... mine is 2007/02 |
03-01-2013, 06:59 PM | #18 | |
73
Rep 965
03-01-2013, 07:26 PM | #19 |
19
Rep 177
I coded this on mine today. And it works somewhat.
It just tells me to shift everytime I hit 1.6k-2k RPM. lol. And I don't think the downshifting suggestion works... I find it more annoying than anything... because I usually don't shift up under 2k RPM... I have a 2011 335i Sedan with a production date of 12 April 2010. |
03-01-2013, 10:38 PM | #20 |
24
Rep 495
Guys, this isn't a shift light that tells you to shift as you reach redline; it's meant for fuel economy. If you're driving around normally (not with the pedal on the floor) it will tell you when to shift to maximize gas mileage. That's why it only works with the throttle setting in normal on the M3. If the car is accelerating, it's not going to tell you to shift. But as your rate of acceleration for a given throttle position begins to taper off, it tells you to shift.
I coded this on my car and only kept it for a day. It's next to worthless on the M3; that car isn't meant to cruise around at 1,500 rpm in 4th gear. I found real-time mpg (DIGITAL_KVA) to be a much better solution. |
03-03-2013, 07:31 AM | #21 | |
73
Rep 965
