dtc question
05-02-2007, 11:19 AM | #1 |
90
Rep 1,717
Drives: lifted tacoma on 38's & ducati
dtc question
when i hit the button and it shows on the display that means its off?
and how much does this really effect performance and acceleration when its on? thanx
car totaled out !!AW335i, oem aero lip, m3 csl rims, oem m3 sides, vorst csl carbon trunk, tinted, lowered on H&R sport, AR DP's, Bastauck dual exhaust, BMS intake, etc
NEW RIDE white GTR! |
05-02-2007, 11:23 AM | #2 |
576
Rep 6,750
When you floor the throttle, the DTC will no longer cut power to the engine to minimize tire spin.
05-02-2007, 12:01 PM | #3 |
17
Rep 729
This is actually something you can definitely use the button with but I will answer your question regardless.
When you hit the DTC button once, the DTC display should light up on your dash. This means that you should for the most part have to interference on typical slight wheel spin when you're at Launch and at WOT. But at the same time if you were to go sideways or spin the wheels a little excessively, the DTC will still kick in and save your butt for the most part from hitting the curb. (This isn't fool proof btw) Think of it like riding a bicycle with training wheels, it will prevent you from falling over, but you still have to make sure you're not crossing the street without looking at both ends to make sure there are no cars coming. Now if you were to press and HOLD the DTC button. Another display will pop up indicating that if you lose control of your car now, there's no help and bent wheels and control arms are going to be your gift of the day. This feature is great if you're doing burn-outs or trying to drift your car. Make sure you use this feature only if you're in an area where you know you're not going to hit something if you loose control of your car. Hope this helps.
RIP 2007 335i Sedan
05-02-2007, 12:20 PM | #4 | |
205
Rep 2,002
When you hit the DTC button once, it means that DTC is now ACTIVE and DSC is LIMITED. DTC active will allow for more tire spin/traction but the system will still intervene if there is too much loss of traction. If you press and hold the DTC button for about 3 seconds, it will disable the DSC (Dynamic Stability Control) and turn all traction/stability control off. The steering wheel movement, vehicle speed, transverse acceleration and yaw are all used by DSC to register imminent instability when cornering. DSC then intervenes via the engine management system, reducing drive torque and activating wheel brakes when necessary to keep the vehicle stable. These events occur within milliseconds. DSC constantly compares vehicle speed, wheel speed, steering angle, and yaw rate with a benchmark of plausible and optimum driving conditions' data. In a fraction of a second, DSC recognizes a threatening instability and a danger of skidding. The DSC system can correct an unstable driving condition by applying precise braking action to the individual wheels. As with ASC, DSC will if necessary also cut back the engine speed to automatically stabilize the vehicle. The DSC computer constantly calculates an ideal driving condition that is compared with the current status. If the vehicle oversteers or understeers, the calculated ideal deviates from the measured status, and DSC will intervene within a few milliseconds Hope that helps.
05-02-2007, 01:07 PM | #6 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Thats a great question. Being that DSC is still on, your car wont be sliding into walls if you turn off DTC. However, you will get a little slippage and the car could shimmy side to side in situations. Ive experimented with both and feel that this car needs all the stability it can get and I leave it all on when its wet out. Dry, all bets are off.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
05-02-2007, 01:11 PM | #7 |
Rep 75
Depends on your skill and driving ability! if you turn it off...becareful or you could be facing the wrong way in traffic in a split second.
07 335i – SG, 6M, Terra, Brushed alum, Sport, Premium, Cold, Nav, CA, PDC, iPod, 15% Tint "The Ring" |
05-02-2007, 01:13 PM | #8 |
Rep 15
Quick question on the E90/2 DSC/DTC. Do you still need to know the secret handshake to turn it off?
E46 Orient Metallic Blue 325i Mods: -Carbonio Carbon Fiber Cold Air Intake -Sirius Sportster Radio |
05-02-2007, 01:25 PM | #9 | |
17
Rep 729
Also, I heard that for the older models there is a MOD-CHIP for those who dont know the handshake! PM ME, i'll hook you up with a great deal
RIP 2007 335i Sedan
05-02-2007, 02:15 PM | #10 | |
20
Rep 235
05-02-2007, 02:18 PM | #11 |
50
Rep 1,600
Drives: e90 335i
no, dont press anything=max stability and almost zero wheel spin, push once=more wheel spin but still DSC operational, push and hold=fully disengaged (ABS and some other aspects cant be fully turned off)
05-02-2007, 02:22 PM | #12 |
342
Rep 6,188
Like what the poster said above. Dont press anything and all protection will be activated. If you DO press the DTC button once, youll see it light up on the dash and that means its been turned OFF. If you hold it down longer it will turn BOTH DSC and DTS OFF. Not touching anything is the safest bet when its raining.
13 HD FatBob
05-02-2007, 02:35 PM | #14 |
147
Rep 5,080
Drives: 530d
you could also read all 270 posts in this thread:
http://www.e90post.com/forums/showth...hlight=DSC+DTC
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i Now: 530d |
05-02-2007, 02:46 PM | #15 | ||
20
Rep 235
"2. DTC is the system optimised for low traction conditions. DSC is not off, but it is restricted as it says in the idrive message." based off of this quote, it sounds like in rainning conditions, it would be best to push the DTC to have better traction, but as mentioned by previous members, it's not... |
05-02-2007, 03:02 PM | #16 |
147
Rep 5,080
Drives: 530d
Yeah, it got a bit heated, protracted and useless after a point.
the gist of it all is:
05-02-2007, 03:20 PM | #17 | |||
20
Rep 235
yeah, explanations like these, in plain english and not such much of technical terms, makes it much easier to understand the concept of DSC and DTC, unlike those 270+ post of foreign language going back and forth at each other |
05-02-2007, 03:57 PM | #18 | |
342
Rep 6,188
This doesnt mean that rain is a low traction condition, just a less than optimal traction condition. Therefore, the car wont not move if you leave all inhibiting traction devices on. Hope that makes some sense.
13 HD FatBob
05-02-2007, 06:10 PM | #19 | |
20
Rep 235
Here in Texas we don't really have to worry much about snow, so I guess it's not really a big issue about DSC...only rain and it's awkwards periods and cycles |
05-02-2007, 08:46 PM | #21 |
90
Rep 1,717
word, thanx bros... def understood much better but, lol
does having everything on and not touching any buttons hurt 0-160 and quarter mile times???????
05-02-2007, 08:52 PM | #22 |
82
Rep 5,732
yes.
And please for the sake of the santity of this here forum do not continue this dtc on/off thread. Some of us required therapy after the previous thread concluded (the one the kind previous poster referred you to)
__________________________
2016 435 xdrive GC white on black leather interior, Msport1, Msport2, premium package 2015 Lincoln MKX, silver on brown leather, premium package - that's right! Techno-Groovy baby |
