2006 325i vs. 2007 323i
05-01-2007, 02:56 PM | #1 |
Rep 124
I was very close to pulling the trigger on an '07 323i but the more I think about the more appealing an '06 325i is becoming. I can get the 325i (used, with some miles on it) for less than the 323i and with a better finance rate.
Consider - 325i more affordable and BMW Certified - more standard features - 215hp 3.0 L vs the 323i's 200hp 2.5 L Am I missing something here or should this be a no brainer? As a BMW virgin I would appreciate any adivise/opinions this forums wise sages can provide. Thanks (Canadian, hence the 323i's availability). Last edited by Dave_H; 05-01-2007 at 03:19 PM.. Reason: bump |
05-01-2007, 05:32 PM | #5 |
Rep 83
I'm thinking that the used 325i is a better deal. What are the options? I have a 2006 323i which I bought slightly used with Premium & Sport packages, so it's decked out pretty much to the max. And it's a sweet ride, although only 174hp ...
Financing is quite a bit better on used and the pre-owned Certified warranty is pretty good. |
05-01-2007, 06:12 PM | #7 |
112
Rep 2,589
or if you can find a used 323, then you save even more $$
05-01-2007, 10:50 PM | #11 |
Rep 268
While I agree with the other posts that the 325 is likely your better bet, you may also want to consider the "past use" of the 325...I would be wary of taking a demo, for instance. gl
05-02-2007, 06:31 AM | #12 |
16
Rep 193
325i, warranty is longer than the new 323 because the 325 is certified pre-owned. But like anything else, certified doesn't imply accident free. Inspect it as you would any used car.
2007 E93 335i Alpine White Auto/CPP/ZPP/ZSP 2012 CT200H 2009 X5 Workhorse/Kidmobile |
